Suspension model
Suspension model
Has anyone done a stock suspension model like the one in this link
http://farnorthracing.com/autocross_secrets16.html
I'm not sure what everything means and teaching yourself is somewhat difficult
Just trying to figure out the perfect spring rates/frequency for *****-n-giggles. Im not keeping this car for much longer but I thought Id try to understand these things before setting up my C6Z
What angle do I want my control arms at for optimal camber gain/ride height
You will have to raise the end of the car 30" to get a worthwhile reading.
Yes, it is scary....
What do you guys use for locking the shocks in place?
Where are you coming up with a 1.5" CG height change as a result of a 5lb diff.? What's the math?
Insert car numbers, including the 10" raised height, then change the loaded number by 5#, result difference is how much?
This is why I had to use 30" height.
Jim M.
