1968 vintage scca road race corvette for sale or trade
A vintage 1968 Corvette convertible race car. A turnkey ( actually, just push the button… ) race car. Its ready to go. ALL fluids have been changed and flushed. Over 120k invested with receipts. Fresh build, 1 test day only. (It’s a rocket !! ) Brand new dry sumped Gibbs SB2 motor, new Jericho transmission, Tilton 3 disc clutch, new 4:11 rear, amazing Nascar style roll cage, 3 way Halon fire suppression system, new seats and belts, cool shirt cooler and shirt, 3 sets of wheels and tires including a brand new set of Hoosier slicks. Lightweight Greenwood wide body, with fully removable body panels. Trans and diff coolers, full heim joint suspension, adjustable sway bars, huge radiator,Painless wiring system, Bilstein coil overs, Randy’s custom rear end, with Toms big axles and studs. Willwood pedal and Willwood 4 piston big brakes all around that haul this ballistic Corvette to a stop…… VERY quickly. The list goes on and on. No expense was spared in building this Vintage rocketship.
Ok here’s the COOL part. The car comes with TWO log books, and a clear title. The first log book dating back to 1972 !! The car raced at famous courses like Watkins Glen, Mid-Ohio and all the big tracks. Good finishing history. This is the real deal Vintage Corvette race car. Not for the timid, or weak of heart. In the right hands this car is a first place car, no excuses, it’s all there, and ready to go. The second log is current and has a 2013 tech inspection done to it. Put gas in it and go. This car can run in all the Vintage classes, GT1, SPO,V8 Stock car, or dozens of other race groups !!
Long list of spares, brakes, rotors,4 a arms, half shafts, u joints, bearings, plumbing hardware and hoses. Gauges and wiring, belts hoses, fuel pumps, and filters, manuals, set up sheets, and much more.You’ll be quite happy.
Don’t let life, or this opportunity pass you by.
Asking price: $65,000, OBO PRICE REDUCED FOR THE HOLIDAYS 49K STEALS IT !!
I urge you take make a realistic offer, Add it all up and it’s around 120k. My loss might be your lifelong dream come true. Check the price against some of the real quality pieces on the race site,
http://www.race-cars.com/carsales/complist.htm
Just finished a 3 year build on this 68 Corvette, completed in 2013. This is a rock solid 1968 corvette chassis with full NASCAR style cage and supports.
Independent rear suspension, near zero scrub front suspension. Chevy SB2.2 engine and Jericho 4 speed set up with overdrive. Chassis engineered by Jay Roese, GM auto engineer and motor built by TWE machine and Gus Brewer from Gibbs Racing.
Engine
• Engine Builder: TWE machine/Gus Brewer Gibbs Racing
• Manufacturer: Chevrolet
• Type: SB2.2
• Displacement: 358
• Horsepower: 805 Built for longevity !!!
• Torque: 766
• Induction: Holley 4bbl, high-rise manifold
• Heads: GM SB2.2. fully ported by Gibbs racing
• Block: GM Bowtie
• Main Caps: 4 bolt splayed
• Crankshaft: Bryant
• Connecting Rods: Carrillo
• Pistons: CP domed
• Camshaft: reed roller
• Valves: Titanium
• Valve Train: T&D rockers,CV pushrods
• Clutch: QM
• Pressure Plate: QM
• Flywheel: QM
• Exhaust: 4-2-1 stainless hand built
• Total Time: Dyno time only
Fuel System
• Fuel Cell
• Manufacturer: ATL, Fuel Safe
• Age: new
• Capacity: 32
• Fuel Pump: Holley electric
• Fuel Type: 110 octane min.
Oil/Water System
• Radiator: Aluminum dual cross flow
• Water Rad Location: front
• Water Pump: Howard Stewart
Electrical System
• Ignition: Electromotive multicoil
• Alternator: CV single wire
• Battery: 16 volt with charger
Transmission
• Manufacturer: Jericho
• Type: 4 speed with overdrive 3rd
• Gears: changeable
• Shifter: Hurst pro. setup at Gibbs racing
• Trans Cooler: yes and pump
• 3rd gear setup as overdrive
Rear End
• Manufacturer: Randy’s rears/GM
• Type: GM Corvette
• Cooler: yes and pump
• Ratio: 4.10
• Case: iron corvette racing HD
• Differential: limited slip
• Axles: HD custom
• Converted from 10 bolt ring gear to 12 bolt (stronger)
Body
• Construction: 1973 corvette with ACI turbo flairs. Fiberglass
• Color: Black
• Paint: enamel
• Condition: very good
• Flames on front just for fun
Chassis
• Type: Fully caged corvette
• Builder: TWE and Jay Roese
• Material: steel
• Finish: enamel
• Condition: new
• Front Suspension: unequal arm, near zero scrub and bump
• Rear Suspension: Guldstrand 5 link independent,HD hubs and bearings
• Shocks: Bilstien monotube coilovers, new custom valved
• Brakes: Outlaw calipers, Coleman discs
• Steering: Woodard R&P power
• Wheels: Diamond 16
• Tires: Hoosier slicks and TDs
Interior
• Color/Finish: Gold enamel
• Material: steel panels
• Fire System: Firebottle remote w/ 3 sprayers
• Restraints: 6 point
• Gauges: full assortment
• Steering Wheel: padded 3 spoke, quick disconnect
• Condition: Excellent
This car will make someone very happy. All the hard work has been done.
There are a bunch of races on the schedule for the remainder of the year in Florida and the big season finale in Texas. Buy it, and I’ll crew for you in Palm Beach or Sebring. The car is located in South Florida.
You could already have the race car in your garage, and it would cost you more to duplicate then what I am asking for this car !!
$65,000 obo Money talks….. Cash, check, or late model Corvette trade !!
Call before it’s gone.
Bruce 561 632 9706
Dozens of pics available. Just email me at offshore241@aol.com
All offers and trades considered !!
Engine
• Type: SB2.2
• Displacement: 358
• Torque: 766
• Block: GM Bowtie
• Pistons: CP domed
• Valves: Titanium
• Clutch: QM
• Flywheel: QM
Fuel System
• Fuel Cell
• Age: new
• Capacity: 32
Oil/Water System
Electrical System
Transmission
• Gears: changeable
Rear End
• Type: GM Corvette
• Ratio: 4.10
• Axles: HD custom
Body
• Color: Black
• Paint: enamel
Chassis
• Material: steel
• Finish: enamel
• Condition: new
Interior
Bruce 561 632 9706
Price reduced to 49k !! Buy it for the holidays !
This car has an amazing roll cage.
15k price reduction 49k owns the car !!
It race ready.
561 632 9706
It race ready.
561 632 9706
Yes, there are actually several groups that you can run with.
SCCA, it runs in Vintage with treaded tires, and SPO or GT1.
It would run well on slicks with the great guys at V8 Stock car.
HSR, and SVRA have run groups as well. There are some cars in both groups with some crazy engine set ups !!
Not to mention, making the Porsche and Ferrari guys weep on track days.....
HSR is Run What you Brung - and Hope You Brung Enough.
Richard Newton
Richard Newton
GETTING READY TO SCHUEDLE ANOTHER KNEE REPLACEMENT...
TALKING ALL OFFERS AND TRADES, HELL.... I'LL EVEN TAKE THE SB2 OUT FOR ANOTHER PROJECT, AND YOU CAN PUT IN YOUR OWN SMALL OR BIG BLOCK CHEVY.
6 KNEE SURGERYS,....I'M STARTING TO THINK I NEED A PADDLE SHIFT AUTOMATIC.....
We just added a helmet blower, and did a complete nut and bolt tightening. The car has fresh fluids and is race ready !!
MAKE A RESONABLE OFFER OR DECENT TRADE, AND YOU CAN BE RACING AT PBIR NEXT MONTH WITH HSR !!
CA$H TALKS !!
561 632 9706
CA$H TALKS !!
561 632 9706
