Hoosier R6 PSI? C6 Z06
I try to keep them 30-32 hot. I seem to lose the back end when the pressure goes higher then that. To get to the 30 mark, I start them at 24ish but that's greatly dependent upon weather. I'm talking about road course temps, not street driving. Good luck.
Here's a good Hoosier Tech Bulletin about stuff such as initial heat cycle, optimum tire temps, camber settings, and of course pressure recommendations:
http://www.racetire.com/products/tctips.htm
You can see Hoosier says for a car like ours that weighs more than 3,000 lb, run the R6 at hot pressure of 38-43+ psi.
Bob
Bob
