WTB Z06 front caliper pistons
I need 6 to fix a old caliper. Can be used, but need to look good.
Thanks Dale
I just want the stock alum. pistons, Not the SS ones.
Thanks Dale
Without doubt the DRM SS pistons are what you want!!
Also, if you need to install new seals and dust boots, here's what I used:
You can see the part is Carlson 41290 for the fronts, and the rears are 41291. Do a search on eBay for those numbers and you'll see the fronts are about $9 for each caliper, and the rears are slightly less.
Bob
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
I threw mine away while swapping to SS. I am surprised no one has offered you some already. Maybe everyone has thrown theirs away, too, when swapping over. I know you want the OEM but I have to wonder why considering the SS are so much better considering less heat transfer to the fluid among other attributes. Anyway, good luck on your search.
