C4 lower hose 1 3/4" needed!
Swapping out my water pump for a higher flow model...and the neck on the pump is 1 3/4" compared to the 1 1/2" of the stock one. Also, the OEM is pinched down in the middle and expanded on the ends. I want one that is 1 3/4" all the way through.
Just wondering if any of the C4 racers had done this and had a part # for it...I'm taking the old hose to NAPA tomorrow and just going to start looking until I find one, but some direction from someone who has already done it would help.
I tried to match something up at the local auto parts store also. Wasted a few days then finally bought this:
http://www.jegs.com/i/JEGS-Performan...11242/10002/-1
Not cheap but it works well.
If I can't find one at the parts house...I'll give Jegs a call on Monday.
I found one at NAPA today!
It is part #7927...I think she said it was a Ford lower hose. It works perfectly...all I had to do was cut 2" from the top (at the water pump) and installed a 16" internal spring from another 1 3/4" ID hose and it looks like an OEM part.
SKU is 029769333341
SKU is 029769333341
