Brake Rotor Experiance Z06 Racecar
Old 01-08-2014, 07:46 AM
Tomra Z06
Tomra Z06's Avatar
Default Brake Rotor Experiance Z06 Racecar
Hi all
I am driving stock C6Z calippers at my Z06 racecar and looking for some good rotors.
I have considered LG, Bear etc.
Does anybody have any good experiance to share??
Im not ready for the Big Brake Kit cost yet
Picture of my old rotor after Trackday at Rudskogen last time
Old 01-08-2014, 08:35 AM
JohnAlley
JohnAlley's Avatar
Originally Posted by Tomra Z06
Hi all
I have been using DBA Rotors for the last 2 years without any issues on my racecar. Usually change rotors mid-year but most likely could go all season. I drive the car really hard so brakes and rotors get a good workout.
Old 01-08-2014, 08:45 AM
Tomra Z06
Tomra Z06's Avatar
Hi JohnAlley
Thanks for the feedback.
I have also been looking at the DBA 5000 2 piece rotor.
Is it 2 piece rotor you got or 1 piece?
Old 01-08-2014, 09:16 AM
JRitt@essex
Supporting Vendor
JRitt@essex's Avatar
Tomra,
That is one ugly disc!!! I know you said you weren't quite ready for a full BBK yet, but please check out an article I wrote about Big Brake Kit Benefits you may not have Considered. Sometimes the initial costs can be a bit deceiving vs. the long-term costs & benefits. In my experience (10 years of selling brakes in the aftermarket), a BBK can actually save you money if you plan to keep your car for a few years. Good luck getting your brakes sorted, and let me know if you need any help.
Old 01-08-2014, 04:18 PM
Tomra Z06
Tomra Z06's Avatar
Originally Posted by JRitt@essex
Tomra,
Hi JRitt
Yes this disc is not very good
I will go for only better rotors this year but i guess that I am ready for big brake kit next year.
I will consider the big brake kit from you then
Old 01-08-2014, 04:24 PM
Tomra Z06
Tomra Z06's Avatar
Tomra,
Do you got AP rotors that fit the Z06 calipper?
Old 01-08-2014, 05:50 PM
63Corvette
63Corvette's Avatar
This pic shows why most warn against drilled rotors on track cars.
Old 01-08-2014, 06:48 PM
Bad_AX
Bad_AX's Avatar
Tomra,
Jeff,
Whey don't you guys offer a direct replacement rotor for stock calipers? Something like this? http://www.essexpartsblog.com/news/c...-big-brake-kit Later on, the calipers could be added.
Old 01-09-2014, 01:39 AM
Tomra Z06
Tomra Z06's Avatar
Originally Posted by Bad_AX
Jeff,
Bad
I totaly agree
Anyone have any experiance about those?
http://store.tkoperformance.com/0614z0frtwop.html
They look very good.
Old 01-09-2014, 06:31 AM
JohnAlley
JohnAlley's Avatar
Hi JohnAlley
They are the 1 piece rotors, I looked at the 2 piece but for the price and amount of use I get out of the 1 piece I could not see paying the higher cost of 2 piece
Old 01-09-2014, 06:38 AM
Tomra Z06
Tomra Z06's Avatar
Hi JohnAlley
I will probably go for these.
Ill let you know what my experiance will be
Old 01-09-2014, 08:11 AM
rfn026
rfn026's Avatar
I just posted my most recent article on brake rotors. You might want to take a look.
Richard Newton
Old 01-09-2014, 08:14 AM
Tomra Z06
Tomra Z06's Avatar
Richard Newton
Thanx rfn
I will check it out
Old 01-09-2014, 09:05 AM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
Hi JohnAlley
After what happened to your stock drilled rotors, you're going to get another set of drilled rotors? Do they not offer "blank" or slotted rings for those 2-piece rotors?
Old 01-09-2014, 09:15 AM
urtoslo
urtoslo's Avatar
I run the DBA two piece rotors. They are not drilled.
I would stay away from two piece rotors that are drilled.
Old 01-09-2014, 09:27 AM
Tomra Z06
Tomra Z06's Avatar
Hi urtoslo
Thanx for the feedback.
Do you got bad experience with the drilled disc?
Old 01-09-2014, 09:38 AM
urtoslo
urtoslo's Avatar
Yeah, they end up looking like yours after one weekend. I never let mine go as far as you did, but the same idea.
To Brake Rotor Experiance Z06 Racecar
Old 01-09-2014, 03:17 PM
Tomra Z06
Tomra Z06's Avatar
Realy, nice to know.
Then I will consider the slotted discs.
Old 01-09-2014, 05:08 PM
LateBreak
LateBreak's Avatar
I'll also vote against drilled discs, they ALWAYS crack on the track, the exception being some of the higher end BBK's where the rotor was designed with holes. Slotted is better, but I still prefer a standard smooth rotor.
Old 01-09-2014, 06:35 PM
spdislife
spdislife's Avatar
DBA
Quick Reply: Brake Rotor Experiance Z06 Racecar
