Need GoPro Track Video to display Fractions of s asecond
Started using the Hero3 black on 1080-30 narrow and got it transferred to computer but windows video and quick time do not display fractions of a second. is there a way to do it or turn it on? thx
Are you trying to figure out laptimes? I had the same issue and ended up installing GoPro's editing software.
http://gopro.com/software-app/gopro-...-edit-software
yes trying to get lap times. I don't care about laying the time on the actual video I just wanna get lap times to the 1/100th of a second during play back ths
Getting it down to 1/100th of a second will be impossible since the video was recorded at 30 frames per second, which means each frame advances every .033 seconds. That also means at 100mph, you're traveling ~5 ft between every frame. Both of these factors make it tough to pin down exactly when you cross the start/finish.
Assuming you're ok with those parameters, you can get a pretty close estimate. +1 on using a video editor. You can cut the video on the nearest frame when you cross the start & finish, and if it doesn't give you the fraction, just count the number of frames after the last whole second and multiply by 0.03333...
30 fps so you only have 30 samples per 1 sec. close enough for ballpark timing
Any decent video editing software will count frames. Even the free Windows Live Movie Maker that comes with Windows will give you that accuracy (that is 3.33/100th at 30fps).
It depends on what you want to see. I like to see the track so I put a sticky mount behind the rearview mirror. The only issue that I have with it is that it rattles a little bit so there's some extra in the audio. I'm fixing that this year with an external mic that I will run out the back near the exhaust tips. If you want to see more of the driver, I'd go for a rollbar mount.
Steve, I mount the camera on the windshield to get a better view of the track. I don't have the GoPro 3, I have the Hero 2 so when I have mounted it on the roll bar, the view is to much of a wide angle for what I want. Try both and see which one you like better. Hope to see you at an event in the near future?? JD
