Rebuilt HD T56 FS
Old 02-11-2014, 09:10 AM
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
Default Rebuilt HD T56 FS
I have a rebuilt T56 that was a M6 box that we built as back up box for my WC ZR1 race car. The M6 box has the following ratio's.
1=2.66
2=1.78
3=1.3
4=1.1
5=0.74
6=0.5
R=2.9
Final=3.42
This would make a great Road race trans for long tracks or a HD street duty trans. It has ALL new bearing and bushings, including all the shifter rail bushings. All new syncro's, new carbon blocker rings, new bronze guides to replace the plastic ones. This trans also has the large spline output shaft for running a ZO6 or ZR1 differential and the adapter plate. If you are interested in this trans and need the small output shaft we can re-install it and if you have a C5 I can also install the adapter for the C5 diff. There is no core this purchase it outright for the trans. This trans does not have an internal cooler pump, we use a external pump on the race cars.
$2500
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Quick Reply: Rebuilt HD T56 FS
