I can't get the stock radiator to fit laid forward - How?
I'm finding the driver side end tank is wide at the top and hitting the frame rail. The space between frame rails actually widens slightly (about 1/8") in the area the radiator would normally be laid back.
I'm using RAFT (Danny Popp) brackets and I know they usually use aftermarket radiators, but they use ones designed to fit in the stock location.
I know I've seen people lay the stocker forward... ideas?
UPDATE
Had a custom radiator built to my design by Tapp, Inc. in High Point, NC. Glad I took the time to do it right vs. making the stock radiator and old oil cooler work.
UPDATE
You need more of an angle. The bottom of the radiator should be about a half inch from the sway bar. If the tank doesn't seem to fit....you need to take a 3 lb lump hammer and "gently pursuade" the frame rail. Don't worry....a few whacks andit will dimple enough to clear.
Yep
I wound up going with a circle track triple pass rad to keep the hose routing the same. The side benefit was improved cooling.
If hose rerouting is no big deal, keep the dual pass.
John
With all due respect..... A few taps with a hammer to the frame rail is hardly a "frame modification". Use a block of wood and it will be impercievable (not to mention that the radiator will occupy that space). I've gotten the Ron Davis and the DeWitts to fit without a problem after a few taps.
Oh.....and FYI....been running ST-2 in NASA for the last 4 years. Never had anyone say anything about my frame rails being modified.
I completely understand the concept of compliance at the Nationals but I think you would have a very difficult time proving a 1/4" or 3/8" variable between frames since there is definately a certain variance observed between C5's. As I stated....it only took a few taps to make adequate clearance in mine. I've seen others that dropped in.
To further the argument, how would a vehicle that had been on a frame machine and tweaked back into alignment be any different?
I went through this with Greg a couple of years ago, and lost the argument.
On a regional basis, I alerted all the competitors and race directors so they were aware of the "modification" and none had a problem, but on a National level, that's Greg's call.
I wanted to err to the side of full disclosure.
Since you're laying it forward on custom mounts, your options for a replacement radiator are a lot more wide-open and affordable. Personally, I'm planning on running an Afco 16x26 Dual Pass when I do mine. It's thicker than the stock one but a few inches shorter in height in order to fit better in the available space. It will also make the intake problem much simpler to resolve but that's hard to explain until I get around to actually doing mine.
They said since the frame rail was modified, it wouldn't be allowed to run in ST2, only in Unlimited. That was in 2013.
In 2014 they decided to only tag a penalty factor on frame modification in ST, so you can run in ST2, but with decreased horsepower or more weight. I don't recall the point penalty, it's in the ST rules.
If y'all go to Nationals with a radiator that is pushing the frame rails, they night be looking for dimples/notches, so just beware.
Here's how mine was done. This is what they disqualified in 2013 on a National level, but regionally no one cared.
That's really a big dimple. I have to get a picture of how mine is done. Regardless it's BS. How the hell does that give someone an advantage that warrants a HP or weight adjustment? They should give him a job with SCCA.....he's completely destroying the spirit of the rules of ST.
Gay. The intent of frame modification is to prevent you from taking a turd car with crap pickup points and addressing that weakness. That and lowering CG by moving drivetrain components, not notching a rail to clear a radiator. I hope I don't lose sight of what's truly important as I progress through the "ranks".
Go read the ST rules on frame rail mods. Then tell me what you have divined the "spirit" of the ST rules to be. Then tell me how Greg's decision is contrary to either.
The regional guys get it, but big NASA has their heads lodged firmly up their asses. Just like ramming Toyo RRs down our throats, they start with half the rubber of an RA1 but if you want to win now you'll buy way more tires. Shaved RA1s even have more rubber. That's what we get for supporting a for-profit racing body.
Location: If you don't weigh in you don't wrestle Road America
I think it's the classic "give and inch they'll take a mile" argument - the rules are pretty clear:
That is clearly a frame modification, there are several ways around it (one being installing a different radiator like what Travis is thinking of doing - which looks like a better/cleaner install btw). Do I really think that Jody's car should have to run in SU - No. But was he actually forced to run in SU regionally? Again no. This kind of scrutiny only comes up when you run at Nationals and even then I'm not sure if they are going to catch something like a dimpled frame rail - it all depends on how big the dimple is. There are a lot of cases out there where a certain car would like a certain mod - the mod is easily doable but it's cheaper / easier to do it a way that violates a rule. In that case it's better to say no and have the current rules enforced than to say yes and have a giant list of technical bulletins for every mod that infringes on a rule. It's the game we play but calling rule makers names isn't going to help anything, racing costs money and sometimes rule changes/interpretations have to be made, it sucks when they don't go our way but at least can still go racing!
A) Other than the listed exceptions, every Production vehicle must retain its unmodified:
1) OEM frame rails/rear frame cross beam, and/or Unibody, and Sub-frames/
suspension cross-members (in their OEM locations)
2) Strut/shock towers
3) Inner/inboard side of the fender wells (any non-horizontal aspect)
4) Rocker panels
5) Transmission tunnel
6) Floor pan
7) Windshield frame location
4) Rocker panels
6) Floor pan
