Heat protection
Old 02-19-2014, 03:59 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default Heat protection
What's the cheapest and best option for adhesive backed heat blocking material? Going to be routing the exhaust through the trunk area and will be building an aluminum shroud to cover it, but I'm sure that won't be enough.
Old 02-19-2014, 04:52 PM
skxf430
skxf430's Avatar
maybe ceramic coat the exhaust pipes, header wrap, and some ceramic or heat foil.
http://www.designengineering.com/cat...ngineering-inc
Quick Reply: Heat protection
