Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
closeout on a Tire Pressure Monitoring System trigger tool
Old 02-26-2014, 11:21 AM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
Default closeout on a Tire Pressure Monitoring System trigger tool
CUB TPMS Trigger Tool
The easy-to-use CUB TPMS Trigger Tool enables 2004-2009 GM vehicles to recognize a newly installed sensor and is excellent for drivers who have two sets of tires and wheels and need to register their TPMS sensors when changing from one package to the other. Instead of deflating or inflating each tire in order to register the sensor, you simply scan each sensor with the TPMS Trigger Tool. The tool also has the ability to display the information transmitted by the sensor, for example the tire pressure reading and tire temperature reading (depending on the vehicle).
The tool uses six AA rechargeable lithium batteries. Charger is included.
only $19.99 each
use this LINK to order yours
remember that orders for accessories that total over $50 you will get free shipping
Old 02-27-2014, 08:20 AM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
Luke, does this tool work in place of the "magnet" you use on the C-5 cars?
Old 02-27-2014, 02:12 PM
0Luke@tirerack
Former Vendor
no .. .the magnet triggered systems do not need to be electronically initialized
Old 03-02-2014, 10:17 AM
ch47d1sg
ch47d1sg's Avatar
does it work on post 2009 cars?
Old 03-12-2014, 01:12 PM
MIGHTYM0USE
MIGHTYM0USE's Avatar
the batteries that came in mine will not take a charge.
Old 03-12-2014, 08:55 PM
D&C vette
D&C vette's Avatar
placed my order, thanks.
Old 03-14-2014, 11:13 AM
0Luke@tirerack
Former Vendor
it's covered under warranty
call 800-428-8355 ext. 4360
Old 03-20-2014, 10:19 AM
z06fun1
z06fun1's Avatar
Do you have such an item that would work with a 2013 grand sport?
Old 03-21-2014, 02:10 PM
0Luke@tirerack
Former Vendor
yes but, it is not on closeout at this time
the ATEQ VT5
Old 03-30-2014, 06:56 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
The Cub Pro 101 TPMS tool has software that is only up through 2009 model year vehicles.
However, THE CUB TOOL WILL WORK WITH 2010-2013 C6 VETTES!!!!
I ordered several of these to send to a couple of forum members overseas. It cost more for shipping than for the tool, but at $60 total shipped it was still a good deal!!
I knew this tool would work with the newer C6, and I had a chance to confirm that by checking the Cub tool out on a 2011 GS on a dealer's lot. I wasn't able to do a full relearn procedure, but I did a diagnostic check on a sensor and the Cub tool triggered the sensor to transmit its data (just as is required for the relearn procedure), the tool intercepted that signal transmitted by the sensor, and the screen on the tool displayed the data (the sensor's unique ID#, the tire pressure, and "Normal").
The sensor in the 2010-2013 Vette is different from the one in the 2005-2009, and the tool's menu only has up through the 2009 model year.
However, the sensor used in the 2010-2013 Vette has been used in many other GM vehicles for a number of years prior to it being put into the 2010 C6. The HHR, Impala, Monte Carlo, several models of the Cadillac, and others use the exact same sensor as the 2010-2013 Vette.
When I checked the GS on the dealer's lot, I just went down the menu in the tool and selected the HHR. When I scanned the sensor in the GS the tool triggered the sensor and displayed the data.
So....this very cheap Cub TPMS tool WILL WORK with the sensors in a 2010-2013 Vette!!!
Just select the HHR or other vehicle that uses the same sensor.
Bob
Old 03-30-2014, 07:06 PM
BEZ06
BEZ06's Avatar
The tool uses 6 AA batteries - just get some new Alkaline ones (you won't be able to recharge them, but they'll work great).
The batteries that come with it are NiMH rechargeables, and you can easily find replacements for them almost anywhere that sells batteries if you really want rechargeable ones.
Bob
Old 04-03-2014, 07:25 AM
Seadawg
Seadawg's Avatar
Bob
I got one of these Bob, so I'll test it on my 2011 GS over the weekend, thanks as always for the tips
Old 04-06-2014, 12:46 PM
BEZ06
BEZ06's Avatar
Hey Ron - did you get a chance to try it yet?
I was going to try to come up and visit to try it on your car, but I have a neighbor that has a GS so I used it on his car and it worked great!!
I selected several different models of cars that used the same sensor as the 2010-2013 C6 for several years prior to that, and they all worked.
When I selected HHR, Impala, or Monte Carlo, the tool triggered the GS sensors in all cases.
I did a full relearn using HHR, and got the confirmation honk at each wheel (double honk at the Left Rear) indicating that the tool triggered the sensor, the sensor sent out its data, and the TPMS computer in the car logged the data into its memory.
Here's a picture of the screen on the tool after it triggered one of the GS sensors:
You can see in the picture above that I had selected HHR, and the sensors used in the 2010-2013 C6 transmit the temperature. The temp isn't displayed anywhere in the car (should be able to be seen in the DIC, but it isn't). The temp may be of interest to owners that track their car, and this tool will display it.
I don't know what that "Remeasure" means.
Below is a picture of using the tool on my 2009, and you can see that the sensors used in the 2005-2009 do not send the temp out in their data transmission signal:
My neighbor also has a Camaro ZL1 convertible for his wife (I don't know what model year, but within the last year or so) and its sensors responded to HHR, Impala, or Monte Carlo. He has a 2011 CTS-V as well, and I selected CTS on the menu of the tool and although it only indicated up through the 2009 model year it still triggered the sensors in his newer model.
Bottom line - even though the Cub tool's software only indicates up through the 2009 model year for all the vehicles in it, many of the sensors have been used in the same vehicle in earlier years. Or, as in the case of the newer C6, the sensors have been used in other vehicles - and it's easy enough to check various sources to see other vehicles that you can select in the Cub tool to work with model years newer than 2009.
And it's nice to get an accurate readout of tire pressure without even taking off your valve stem caps. Don't put the car into the learn mode, just walk up to your car and do a diagnostic scan of the sensor to get the pressure displayed on the screen.
If you get one of these Cub tools to use with your 2010-2013 C6 Vette, just select HHR on the menu!!
Bob
Old 04-24-2014, 12:27 PM
jcase10
jcase10's Avatar
St. Jude Donor '10-'11
Just bought one, delivery for tomorrow.
Old 04-28-2014, 07:43 PM
T Will
T Will's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19
When I scan my sensors they read but won't sync with the car. I'm in acc in learn mode. Anything else i should do?
Old 04-28-2014, 08:55 PM
StKnoWhere
StKnoWhere's Avatar
Not sure if needed but parking brake set and press lock and unlock on the FOB simultaneously?
Old 04-28-2014, 09:08 PM
T Will
T Will's Avatar
Thanks, I did that, the horn sounds so it should be in the learn mode. It worked on the old wheels. Maybe the old are to close since they stored in the garage.
To closeout on a Tire Pressure Monitoring System trigger tool
Old 04-29-2014, 09:02 AM
BEZ06
BEZ06's Avatar
It doesn't matter where your old wheels/sensors are located - they can be a foot away from the car without affecting the relearn of a new set of sensors.
To enter the learn mode you don't need the parking brake on, but ignition must in ACC (yellow light illuminated on ignition button), and push and hold both the lock and unlock buttons on the fob until you get a horn honk.
Once in the learn mode you must trigger the first sensor (Left Front) within one minute or the learn mode times out.
You say your car goes into the learn mode, and you say you get a readout on the Cub tool's screen.
If you get a readout on the tool's screen then you are triggering the sensor and getting it to transmit out its info to the TPMS computer in the car.
If the horn doesn't honk when that happens then the TPMS computer is not recognizing the signal transmitted by the sensor.
It sounds like you may not have the correct sensors for your model year in your new wheels.
What sensors were installed in your new wheels??
Did you see them? What color are they, and what shape? Are they OE sensors made by Schrader, or are they some aftermarket sensors? What is the part# of the new sensors?
Bob
Old 04-29-2014, 12:17 PM
T Will
T Will's Avatar
Bob
Thanks for your help
I bought the wheels and tires already mounted. Scan tool reads old wheels 2890231. new wheels 3234672 if that helps.
Old 04-29-2014, 04:03 PM
djdinoe
djdinoe's Avatar
Thanks..I ordered one.
Quick Reply: closeout on a Tire Pressure Monitoring System trigger tool
