Help with permanent removal of fuel tank evaporator canister for cage install
How do you abandon the evaporator canister on the right side? With the new hoop on my cage install, there is no room for the canister. I know it is to be removed, but how do I abandon the vent line? If I just cap it, wouldn't that create an unwanted pressure in the tank? Do I just cap the other hoses? Thanks
I think all the vent fittings have check valves already, but double check the larger fittings (remove the crossover tube and still a metal wire in there and see if it hits something).
You need to vent those (or devise another setup) or else the tanks will not be able to adequately breathe, leading to various issues.
Another option is to modify the backwall to allow room for the canister. I don't know all the details on how it was done on my car, but here's a picture. In the picture, the black area with paint runs has been modified with a bulge to allow room for the canister.
The shop that did mine capped them all and now it won't take fuel. 10 minutes to get it like 7gallons in the tank.
I also like to vent above the filler neck/gas cap.
Retaining the charcoal cannister w/o keep the venting solenoid and associated plumbing in place doesn't do a lot of good, as the cannister needs the vacuum to allow the charcoal work effectively. Does make for good ballast in that location though.
Also - what did they cap them with? May want to check the condition as most things don't stand up to gasoline.
BTW that Mantic clutch you sold me rocks! Thanks for that as well
Well, thank you as I think I did a search and came across your post about this a while ago and realized I was going to have the same issue, for the same reason, so I did a lot of searching as to how to avoid the slow fill and fuel flow issues.
Location: If you don't weigh in you don't wrestle Road America
The roll-over valve or check valve is part of the fuel tank, I've confirmed that on a 02 and an 03+ so you should be able to remove everything without issues with fuel running out if rolled. (I'm not sure if the early 97-99 systems are the same as an 02)
Actually on one car if you filled it all the way out fuel would spill out of the RH tank - that told us that the roll-over valve was screwed up. We put in a new RH tank and all was well. I looked into installing an aftermarket check valve but didn't find anything that I liked.
You will know if things are working properly simply by filling your tank, if the fuel spills out of the RH tank something is wrong, if it goes up the filler neck then all is well.
Thanks for confirming. From travis's experience, it seemed like these were "special" check valves in that they work as a typical tip-over valve, but are also pushed close by gasoline.
