O2 Wire insulating
Old 03-24-2014, 11:44 AM
Zak77
Zak77's Avatar
Default O2 Wire insulating
I finally finished my header/cam install and with the amount of heat they now put out and that I do a number of HPDE's a year I'd like to shield my o2 sensors a bit more. What should I wrap the wires in to keep them from melting?
Old 03-24-2014, 02:02 PM
ErnieN85
ErnieN85's Avatar
Easiest thing is to drill a hole above the sensors and feed them above the tunnel plate, otherwise DEI insulation from Summit or jegs
Quick Reply: O2 Wire insulating
