14" rotors with stock c5 calipers?
Was just curious if anyone has had any experience with the brackets that move the stock caliper mounts to allow for the use of 14" rotors. These would help fill out 18"/19" wheels. Would there be any real performance benefit out of them? I guess the larger rotor would take longer to get hot, but are there any other benefits when paired with the stock calipers? Anybody have pics of this set up?
Platinum Supporting Vendor
Why would you want to do that. The whole reason of moving to a 14" rotors is so that you can have more surface area for a larger caliper. Ideally you want to run the smallest possible because of weight. However if the larger caliper is letting you stop quicker than that is more important than adding weight. What you are asking though is to just add weight without gaining any stopping distance. You will probably increase stopping distance slightly just due to the extra weight. The real solution on keeping stock caliper would be how to make them work on say a 12" lightweight rotor.
Received 8,929 Likes
The C6 Z51 calipers were on caliper mounting brackets that allowed them to run a 13.4 in front rotor. Other than that they were basically the same caliper as the stock C5 caliper. You could easily use those brackets to mount a C5 caliper and then use the C6 Z51 rotors or non drilled aftermarket rotors.
Bill
You use big brakes not to go faster but to make them last longer.
To answer the OP's question I have not.
But it should be an improvement in braking. Increasing the circumference of the braking area in fact increases the braking surface. It will add unsprung weight but it will also add extra mass to absorb the heat generated by braking.
Not apples to apples but I know of one former AIX champion that ran 14" rotors with Brake Man calipers and claimed he didn't need to run cooling ducts due to the increased mass of the rotors.
I think the idea is that the caliper doesn't need to work as hard if it's grabbing the rotor further away from the center. Since braking is just applying a torque to the rotor, moving the caliper 10% further away means you achieve the same torque with 9% less force from the caliper - which means you can use a less aggressive brake pad. The larger diameter rotor also means more rotor material to absorb heat.
Not exactly to the OP's point, but for related info see the recent thread on the Wilwood W6A's. I think they are designed for a c6 and the discussion turned to using them on a c5 with a c6 z51 rotor.
Last edited by RDnomorecobra; 04-27-2014 at 07:07 PM. Reason: meant rotor, not caliper.
Torque on a brake is actually by radius of the center of the pad contact to the center of the rotor.
Reason for bigger brakes is for heat soak, not so much torque generally. Plus it's the tire that stops the car not the brakes.
Mmmm carbon ceramic have such a nice energy curve.
Both principles apply. Larger diameter rotor = larger heat sink. Caliper further away from center of rotor = more brake torque. I haven't the first clue of % performance improvement in either area but those two principles apply as a matter of physics....all other things remaining the same.
To the OP if you are looking at a Baer kit they are available with blank or slotted rotors.....call Baer directly for part numbers.
True story. In my case it was not really a case of the part number(s) being different per se, it's just that I needed to specify cheese-graters (in my case) when ordering. Baer Eradispeed +2 "slotted only". No extra charge or cost as such, but it does need to be specified beforehand.
I was not saying that you would stop any more quickly. With the pad grabbing at a larger radius, you can stop at the same rate but without exerting as much force on the rotor. Less force = less heat going into the pad, caliper, and fluid = longer lasting brakes.
Former Vendor
And considering the cost effective nature of this particular kit it's a no-brainer over trying to relocate as stock caliper to larger discs.
The kit allows for both the 13.4 and 14" flavor discs (radial mount spacer included) so the is flexibility in the system for both budget and wheel size.
And if you really want to go crazy you can pair it with FNSL4 rear calipers on an also stock 13.4" rotor for both improved performance and looks. ALL of that for well under $1800 to the door.
C6 Caliper Kits
