Which tire for C5 B Street now ?
Old 04-08-2014, 06:05 PM
GeneT
GeneT's Avatar
Default Which tire for C5 B Street now ?
With the new class designations for 2104 and the wear rating restrictions going up to 200 for 2015, what tire(s), that will fit a stock C5, will be at the lower treadwear (200) rating ?? I was running Hankook Ventus V12's and they are worn out and have to be replaced.
Old 04-08-2014, 07:26 PM
ltborg
ltborg's Avatar
As long as you are OK with slightly shorter tires than stock (which is more competitive), the new Hankook (R-S3 version 2) is probably your best bet. The Dunlop ZII is a good choice, but it has been discontinued in preparation for the ZII Star Spec, which has yet to go on sale in the US. Other options would be the BFG Rival and the Yokohama AD08R.
I personally run the old Hankook and will be switching to the new one as soon as feasibly possible.
Old 04-09-2014, 11:53 AM
Gordy M
Gordy M's Avatar
Is the RS3 version 2 a new compound or just the change from 140 to 200 treadwear. I currently have the 140 version and about 60% remaining.
Old 04-09-2014, 12:03 PM
brenb
brenb's Avatar
Compound change.
Per TireRack:
The new updated Racing Carbonblack Silica Compound (RCSC) technology allows the Ventus R-S3 (Version 2) to retain its 200 Treadwear UTQG rating, as well as reach favorable operating temperatures quicker produce more grip in damp/wet conditions.
Old 04-09-2014, 12:56 PM
ltborg
ltborg's Avatar
Hankook was the company that immediately changed their 140 rating to 200 when the SCCA announced the rules changes. There is no difference between the 140 v1 tires and the 200 v1 tires other than the number on the sidewall.
Old 04-09-2014, 02:03 PM
hklvette
hklvette's Avatar
The AD08Rs are 180TW. No word on if Yoko is going to bump them to 200 like Hankook did.
Old 04-09-2014, 02:06 PM
GeneT
GeneT's Avatar
If they don't they will be illegal next year in the Street Classes
Old 04-09-2014, 02:07 PM
GeneT
GeneT's Avatar
Are you in a C5 ?? Stock rim sizes ?? What tire sizes are you using ??
Old 04-14-2014, 02:25 PM
Race Prepared
Race Prepared's Avatar
Originally Posted by ltborg
+1
Old 04-15-2014, 10:43 AM
Gordy M
Gordy M's Avatar
I am running the 255/40x17 fronts and 285/35x16 rears on Magnesium C5 wheels
To Which tire for C5 B Street now ?
Quick Reply: Which tire for C5 B Street now ?
