Is Anyone Tracking Their C7 Corvette?
Old 04-10-2014, 05:54 PM
George33
George33's Avatar
Default Is Anyone Tracking Their C7 Corvette?
If so, what kind of mods and safety equipment are you running?
I'm an experienced HPDE driver (but not in a Corvette) and I'm interested in some weekend
track events with my Z51 C7.
Some things that come to mind are, harnesses & harness bar, R-Comp Tires & sizes, wheels,
brakes & pads, etc.
Would appreciate hearing what you guys are using.
Thank you.
Old 04-10-2014, 07:44 PM
05C6GAC
05C6GAC's Avatar
Reese @ MTI racing is tracking his, probably all of the above, give him a call. He's a forum sponsor.
Old 04-10-2014, 09:36 PM
George33
George33's Avatar
I probably should have clarified, this would not be for full race track prepared cars,
but for weekend HPDE events.
Old 04-10-2014, 10:37 PM
RapidC84B
RapidC84B's Avatar
Received 13,150 Likes on 5,984 Posts
The C7 Z51 looks very capable in stock form. If I had one I'd get some spare wheels with a sticky street tire, a harness bar and harnesses, and some upgraded pads while ensuring there is good cooling to the front rotors... that's it.
Old 04-11-2014, 01:12 AM
Corvee
Corvee's Avatar
brakes & pads, etc.
Thank you.
A buddy tracks his - stock with the exception of aftermarket brake pads and fluid.
And then there is Reese's car:
Old 04-11-2014, 06:59 AM
jfaphoenix32
Supporting Vendor
jfaphoenix32's Avatar
We have trackedours several times and have a pretty complete list of what needs to be done..
Available:
Harness Bars
Tow Hooks
Penske Shocks
Alignment and ride height settings
Wheel and tire recommendations.
Call Joe at Phoenix Performance if you want an update on what is avaolable.
610-482-0141 jfaphoenix32@aol.com
Old 04-11-2014, 01:20 PM
0MTI RACING
Former Vendor
MTI RACING's Avatar
MTI Racing will be at Roebling Road in Savannah this weekend with our C7 racing with NASA. Come on by if your in the area.
Old 04-11-2014, 03:12 PM
exracer28
exracer28's Avatar
I have heard again and again that Phoenix Performance is the place to prepare any car for track use and they are the real Corvette race shop. Joe and his crew have been very helpful to me and my fellow racers. I suggest a call to Joe before you do anything to your car.
Old 04-11-2014, 04:49 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
We have been doing a number of events on our C7 over the past couple months testing our new suspension parts and packages for customers.
Stay tuned....
Old 04-11-2014, 07:34 PM
George33
George33's Avatar
That's great.
Can anyone make suggestions for harnesses & harness bar, R-Comp Tires & sizes, wheels,
brakes & pads, etc. for tracking the car?
Experienced drivers , please.
Old 04-11-2014, 08:03 PM
RapidC84B
RapidC84B's Avatar
The preferred setup for a C5 is four 18x10.5" C5 Z06 rear wheels. This is actually what MTI was using on their black C7 for awhile. Toyo R888s are a great sticky street tire. I'd get 295s square.
Old 04-12-2014, 12:08 AM
Corvee
Corvee's Avatar
That's great.
Unlike its predecessors the C7 seats are fine. At some point you may want to add a harness & bar but not necessary for starting out. I am not sure who makes a bar for the C7 but there are likely to be choices. The stock tires and wheels are also fine until you are ready to move to R comps, If so an 18" f/r set-up is best. LG carries a Cobalt pad for the stock LS7 brakes - an excellent choice. I would check with Anthony at LG on those (change the brake fluid) and wheels when you are ready.
Old 04-12-2014, 12:37 AM
skxf430
skxf430's Avatar
Is that splitter available yet?
Old 04-12-2014, 08:28 AM
George33
George33's Avatar
Depending on the club, upper run group drivers are required to have safety equipment in the car. I've run with PCA, BMW and NASA events and have instructed with all 3. As the driving level increases, the harness belts are almost mandatory so you're not holding on to the steering wheel in the corners.
I've run R888 tires and would not recommend them for the street, particularly in the wet. (I actually prefer the old Toyo RA1's over the R888's)
This season will be my first time out on the track in a Vette. Would love to hear some feedback on brake pad compounds, aftermarket wheel & tire sizes and if anyone knows of harness bars that still maintain the stock 3-point belts.
Thanks.
PS- Clear bra being installed next week.
Old 04-12-2014, 10:29 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Thanks.
I will be happy to discuss pad compounds with you. Carbotech has several options. What tires will you be using on track?
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 04-12-2014, 11:00 AM
jfaphoenix32
Supporting Vendor
We have been running our C7 Z51 and have tow hooks, shocks, harness bars and suspension setups available.
Call me direct if you would like to discuss..
Joe 610-482-0141
Old 04-12-2014, 01:25 PM
Former Vendor
That's great.
We have not ran our car on slicks yet, doing most of the testing on sticky street tires for the time being.
The factory brakes do work better than the prior generation of cars, but they are going to need upgraded if you are going to get serious with this car and run it on slicks. It is still very much a OEM brake setup, and can not take a radical car with a fast driver at the wheel. For those doing HPDE events, switch it out to Motul fluids and rock a set of Cobalt XR1's front and rear and it will do some pretty amazing things on track. Remember to say your a forum member as the Cobalts are on sale right now to forum members!
VetteWorks and Phoenix both have get solutions for tow hooks, and harness bars....both of which we sell.
To Is Anyone Tracking Their C7 Corvette?
Old 04-12-2014, 08:15 PM
skxf430
skxf430's Avatar
Joe and Anthony,
Are either of you running 18" wheels? If so, what width are the wheels, and what size tires are you running?
Thanks for any info.
Old 04-12-2014, 10:23 PM
George33
George33's Avatar
Originally Posted by skxf430
Joe and Anthony,
. . . . . . " And, which R-Comp tires "
Old 04-13-2014, 11:29 AM
jfaphoenix32
Supporting Vendor
Hoosier A's or R's...
!8 inch wheels all around.. 10'sup fronts 11's to 13's in rear. But rear spacing is tricky so you need to do some spacin and fittin...
The stock Michelin tires are quite good...
Quick Reply: Is Anyone Tracking Their C7 Corvette?
