Shock dyno CVP files wanted
Old 04-11-2014, 09:27 AM
briannutter1
briannutter1's Avatar
Default Shock dyno CVP files wanted
Thanks to a couple forum members, I've become obsessed with shock valving graphs. A lot of the curves that are published don't show hysteresis, nor all the sweeps/clicks if it's adjustable. I've noticed some manufacturers doing adjustables are really just micro adjustments over a wide range of clicks so you don't put yourself in left field (probably a good thing). Also of interest is front vs. rear shocks with the different shock angles/spring rates. If you have any files that you don't mind sharing, pm me and I'll give you my email. Any files are confidential and won't be redistributed.
Quick Reply: Shock dyno CVP files wanted
