Will these calipers/brake kit clear my wheels?!
Old 04-11-2014, 10:23 AM
0Todd TCE
Former Vendor
Todd TCE's Avatar
Default Will these calipers/brake kit clear my wheels?!
How many times have we read this question? Maybe you've asked it yourself being unsure of what space is needed for your plan of attack.
TCE has a new and simple calculator to help with this. A "Caliper Clearance" calculator which takes the spec of the caliper body and combines it with your stock or 2pc hat and rotor to give you the information you're looking for.
CAL CLEARANCE
You'll need to know a few things about your plan:
1. The body size overhang
2. The hat or rotor offset
3. The face thickness of your hat or one piece rotor.
Put that info into this calculator and you'll soon have your Dimension A of this drawing:
Pull a wheel and place a straight edge over the hub of your wheel and measure into the pocketed spoke area. In a matter of minutes you'll know just how close you'll be. *Dim. B and C are going to vary by the diameter of your disc. Take that diameter and divide by 2. Add about one inch to the result and you'll be close on Dim C.
In addition to our BRAKE BIAS and DUAL MASTER CYLINDER CALCULATOR it's one more tool to help folks with their braking needs.
Old 04-11-2014, 10:28 AM
Sox-Fan
Sox-Fan's Avatar
:likebutton:
Quick Reply: Will these calipers/brake kit clear my wheels?!
