Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Can the same size tires/wheels be used on C5?
Old 04-13-2014, 11:16 AM
drseth
drseth's Avatar
Default Can the same size tires/wheels be used on C5?
I will be needing new tires before too long and am wondering if it is possible to change from the staggered 17 and 18 inch wheels and go with all 17 or all 18 inch wheels, running the same size rubber all around.
I am thinking then the tires can be rotated.
Seth Anderson
Moon, VA
Old 04-13-2014, 05:17 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
No.....The car comes from the factory with tires in the rear that are approximately 1" larger in OD than the fronts, and the car's computer programming is set up to see that difference in wheel speed, to keep the traction control, active handling, and ABS in sync.
Old 04-13-2014, 06:06 PM
YLWFVR75
YLWFVR75's Avatar
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Not entirely true. He can go 18's all around. A lot of people do. Just need to ensure the rear tire diameter is 0.5" inch or larger than the front diameter.
I've got 275/35 (25.6") in the front and 295/35(26.1") with no issues.
Old 04-13-2014, 06:25 PM
leadfoot4
leadfoot4's Avatar
Re-read his post.....
He wants the same size tires all around, so he can rotate his tires.
Old 04-15-2014, 01:39 PM
breecher_7
breecher_7's Avatar
You can do it just fine...
Lots of people run 18x10.5 square on the C5.... Pisses off the electronics but who cares....
Old 04-15-2014, 09:57 PM
chetly
chetly's Avatar
Ive seen plenty of autocrossers running 315 square on c5's. they seem to do just fine...
Old 04-15-2014, 10:31 PM
Armycop
Armycop's Avatar
I'm one of 'em. Been running 18" 315's on all four corners for years now. Electronics are just fine. All the nannies work.
Old 07-24-2014, 07:47 PM
80535's Avatar
How does the 315 fit on the front? Do they stick out of the wheelwell?
Old 07-24-2014, 10:04 PM
MT99FRC
MT99FRC's Avatar
I have the same thing going on I wanna run 18x10.5 squared with 295 or 315's but what about back spacing all I can find is wheels with 65 back space front run around 50 I know people have this set up but how does it not rub?
Old 08-17-2014, 09:58 AM
m6 c5
m6 c5's Avatar
I'm running 295 35 Goodyear eagle f1 up front and nitto 305 35 555r's in the rear with I problems at all.
To Can the same size tires/wheels be used on C5?
Quick Reply: Can the same size tires/wheels be used on C5?
