"Hubstand" Diy alignment and setup tool
A notable Miata shop (FM) is making an alignment hub mount stand which i think i can use for my C5Z. These hubstands make adjustments WAY EASIER given your access to adjustments w/o wheels. They are $395 pair BUT, the slotted mounting design makes them universal for 5 x 100mm thru 5 x 130mm for both 12mm and 14mm studs...meaning i can use these on all my cars! And others
Has anyone here used these FM stands on a vette? Curious to know if there are any clearance issues.
I also posted this in case you DIY alignment guys didnt know about these. Check them out.
If they fit, i really would like 2 pair for use with my smart strings. Thats a hot setup for sure and a universal setup which would fit ALOT of different cars so yeah, its an investment toward Diy alignment.
Right off the bat i see the adaptor is limited to certain sizes, I have to buy 4, plus they are way more expensive- these START at $895. the vette stands list for $1195! That seems a bit crazy to me. That puts them out of my price range.
The fm stands have toe sticks included and more universal for $395 pair, so if i want (or cant afford) i can start w 2. This unfortunately, i may have to do. Even $800 for 4 fm stands, thats a hefty price of admission for me...they're gonna have to save me ALOT of time doing alignments.
You can get adapters that are drilled for multiple sizes.
The Hubstands are, I'm nearly certain, a more accurate alternative but are slightly more expensive (after a handsome rebate, if you are a racer). The FM ones may work out fine for you. Go for it.
