Trailer Tire Pressure monitors
Old 04-27-2014, 09:40 PM
JDIllon
JDIllon's Avatar
Default Trailer Tire Pressure monitors
Anybody running these? what brand? What did they cost and are you happy with them? Thanks, JD
Old 04-27-2014, 10:05 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Hey JD
When we talked the other day you said you might be up this week - if so you can take a look at mine.
Here's the set I have for my trailer:
http://www.jegs.com/i/Orange-Electro...ductId=1287069
I can't remember where I got mine, but I think it was around $165.
It's made by Orange Electronics, and seems to work fine. I've only done one tow where I use it - 300 mile round trip down to the Sebring event 2 weeks ago.
The display alternates between the tire pressures and temperatures.
See ya in a couple days if you make it up this way.
BTW - remind me to show you the emails I have received from Kirk. They are very promising concerning getting repairs under warranty!!!
Bob
Old 04-28-2014, 11:59 AM
Superbee
Superbee's Avatar
Hi Jim
I have a set, Ron Art's pal put me onto them. For the price a definite good idea
Old 04-28-2014, 12:59 PM
RX-Ben
RX-Ben's Avatar
Truck System Technologies (TST).
Works very well and the sensors screw onto the schrader valves.
It is more expensive, but it is more of an industrial system.
The cheaper ones do not get particularly good reviews on Amazon.
Old 04-28-2014, 04:28 PM
flink
flink's Avatar
Yes, the tsttruck.com system works well for me. A couple of the senders did fail after a couple of months but the other four have been running happily for a year or more.
I lost three valve stems in a single 700mile tow (much of it at 70mph). The stems were rubber, and quite old. All three came dislodged from the rim and slowly leaked down. So if you're using the senders which screw onto the valve stems then do get metal valve stems or at least freshen up your rubber ones.
Old 04-30-2014, 11:12 PM
OVG
OVG's Avatar
I have the TST system with the sensors inside the wheel. I bought six sensors to cover the tires on the trailer and the two spares. The display rotates through the four tires showing pressure and temperature for each tire. After my first trip, I did have them inflated with nitrogen due to the pressure fluctuations setting off false alarms. The alarms are user programmable and I set the ranges too tight. After the nitrogen and changing the settings, no more false alarms. Nice peace of mind to be able to know what's going on back there.
Old 05-01-2014, 07:54 AM
TorontoC6
TorontoC6's Avatar
I have TST. I think they cost ~250 for kit with 4 valves.
They work well but make sure that you have metal valve's and not rubber.
Old 05-01-2014, 08:02 AM
1991Z07
1991Z07's Avatar
TST ...bought their system to cover all the tires on the RV and the trailer.
Top notch system...and gives you some real peace of mind when blasting down the highway.
Paid for itself within 24 hours after installation. Pulled out on the highway the next morning and the alarm went off. One of the tandem rear wheels on the bus was showing a slow leak. Pulled off and went right to the tire shop 2 blocks away. Picked up a nail on the inside tire...and it would have only been a matter of time before it came apart.
Instead of a $900 tire, it cost me a repair. Good stuff...
Old 05-01-2014, 07:41 PM
sgsvette
sgsvette's Avatar
Jim,
look at both my trailers Saturday. I have 18 on the semi and 4 on the tag. I also have them on my bus. Expensive ($1,000 per set) but well worth the money.
To Trailer Tire Pressure monitors
Quick Reply: Trailer Tire Pressure monitors
