Tow Hook for a WC Front Bumper?
Old 05-03-2014, 11:27 AM
jlutherva
jlutherva's Avatar
Default Tow Hook for a WC Front Bumper?
I need a front tow hook for a C6Z with the Black Dog Speed Shop fiberglass front fascia. This bumper extends several inches beyond the factory part so standard tow hooks do not work. The overall length of this hook needs to be about 17-inches so it has to be stout or it'll destroy the grill or bumper if towed even slightly off-line.
Black Dog cars use a tubular framework between the frame and the fascia so they don't have this problem. Phoenix only has hooks for standard configurations.
Suggestions?
Jim
Old 05-03-2014, 08:18 PM
Hi Volts Z06
Hi Volts Z06's Avatar
I had the same problem. I fabricated a custome piece but found that the extra length tends to act as a lever and when you need to use it, deforms. My fix was a simple one- I went to a nylon tow strap. You just need to get a really large fender washer to "sandwich" the strap against the bumper (the steel factory bumper....not the fascia!)
Old 05-04-2014, 12:49 PM
jlutherva
jlutherva's Avatar
Excellent suggestion/solution. I'm going to install my existing Pfadt prototype tow hook and I'll attach the tow strap to that. I'll have to step the Pfadt tow hook down another inch to provide clearance to the fascia and make a bigger space in the screening for left or right pulls and that will work.
Thanks!
Jim
Old 05-05-2014, 09:39 AM
vette6aut0x
vette6aut0x's Avatar
Have one. PM me.
Old 05-05-2014, 08:39 PM
rmackintosh
rmackintosh's Avatar
Tow strap is probably the best option. I fabled a plate to my fabricated race car bumper, so was simple...but if you don't have that structure...
To Tow Hook for a WC Front Bumper?
Quick Reply: Tow Hook for a WC Front Bumper?
