Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
corect tire pressure for C5 Non-Run Flats
Old 05-18-2014, 01:08 PM
92PGC
92PGC's Avatar
Default corect tire pressure for C5 Non-Run Flats
I just put Hankook Evo's on my 2003 C5. the shop put 28 PSI which I thought was low. I put 35 which according to the TPMS warmed up to 39PSI on yesterdays cruise, which I think is high.
I have been unable to find anything on Tire Rack or the Forum which provide the specs for Non-runflats. I want to stop guessing.
thank you
Old 05-18-2014, 06:46 PM
dankhts
dankhts's Avatar
If you're still running stock size tires, just go with the manufacturer's recommended tire pressure, it's on a big sticker inside the driver's door..... Run flats or non run flats makes no difference.
Old 05-21-2014, 12:28 PM
johnandsarah002
johnandsarah002's Avatar
I believe it 30psi cold
Old 05-23-2014, 04:52 PM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
correct
and correct
Old 05-24-2014, 06:13 PM
StKnoWhere
StKnoWhere's Avatar
A 4 psi rise sounds normal, With 30 psi cold 34-36 warmed up is about right
To corect tire pressure for C5 Non-Run Flats
Quick Reply: corect tire pressure for C5 Non-Run Flats
