Looking for 68 to 74 Project car.
Looking for any corvette between 68 and 74 to restore. Looking for a project car. Hopefully close to Newfoundland, Canada
Frame can be bad, I have a good frame.
1969 Vette - 427/390HP 4 speed - Factory Air
LOTS & LOTS of new parts need finishing
Fresh engine (correct "ORIGINAL" engine)
New wiring, interior, suspension, paint, etc.
More pics & info ===>> 1969 Vette Project
George
George
email sent, looking forward to your reply
pm me at 4wesbrenton@att.net I have a 68 project
Wes
Wes
c-3 project
Vin sequence denotes late November or early December 1967 car, was Lemans or International blue. One piece nose and inner fenders, long hood wiper delete, NO RUST NO CORROSION! super solid bird cage. Was western/desert car and has been stored the last 15 years. Will make a great resto rod or street car. Was in original blue automatic bbc with ac car. I am offering a couple different motor trans combinations. (1) stroked sbc 417cu #511 400 block offset ground crank, 5.7 small journal rods, large solid crane cam/brodix aluminum +.100 2.19 intake, 188 exhaust ported polished bowl matched heads and are empty, need rebuild... Complete ACCEL mini tps tunnel ram ported and polished injectors, fuel rails, complete engine wiring hookup for a c-4 corvette with cal map adjustments/or a complete new closed loop harness/system for installation in any car with ecm and distributor and jet coat headers... Art car 700 r4 no lock up trans and two torque converters (2500/3000), drive shaft included. Frame is complete in gloss imron and ready to be assembled with complete 3:55 rear end assembly rebuilt a-arms, front suspension is power steering/wheels and tires Cragar ss 15" wheel and tires. Core bumpers, front and rear, headlight assemblies, gas tank, black seats, black dash, some gauges and some harness, steering column, steering box, convertible top assembly are included, and are JUST SOME OF THE PARTS AVAILABLE. (2) A 454/427/396 bbc/4 speed combination is also available in this project. Car will leave with one or the other. Can put together a package for almost any need. Steel dolly body sits on now is not included but can supply a wooden substitute if needed. 603/673-0234, Milford, NH 03055 $7500. or for all the pieces less motor and trans: $5000. i also have for a combnation with this car is an UNSTAMPED FRONT PAD 3963512 4-bolt main BLOCK, high distributer tower[early production] large oil cooler return line over filter boss, with a set of #3919840 435hp l-71 heads completely rebuilt, never used very nice shape, ready to bolt on, please look at pics for dates,set of rods 3/8 or 7/16, with a usable 6223 crankshaft that will need to be turned to size, and a 4 speed trans[muncie or bw] i have more than a dozen of them and no, the m-22 are gone!, but probably have a 621 bellhousing and a clutch and shifter set too that i will include......Thanks. Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
1970 Corvette Stingray Project car available
I have a 1970 Stingray Corvette which was a factory 350 with 350 HP with a 4 speed. The car does not have the original motor but had it replaced a number of years ago with a GM LT1 crate motor.
The car has been sitting for about 20 years and needs a decent amount of work but the frame is solid and the fiberglass is also in very good condition.
Located in Michigan.
1970 Project Stingray for sale
dustin zosky (10-19-2015)
70 vette project
Actuality I was talking about the one you bought few days ago the 70.
It looks a good car how much did you pay for it , if May I know.
I have a 74 but I would like to buy a 69 to 73 because I like the flat rear, I'm just curious about how much you pay for yours.
I also have a 74 but always wanted a 70 (The same year I was born) They are the nicest looking of the C3s IMO.
So I keep an eye out for a 70 to come up for sale, saw this and jumped at the chance right away.
