C3s for Sale/Wanted Private Classifieds: Used C3 Corvettes For Sale, Modified or Stock Corvettes, and Restored or Original Corvettes
1981 Pro-touring 6spd swap 7000$ obo
Old 08-21-2014, 07:52 PM
dixiespeed81
dixiespeed81's Avatar
Default 1981 Pro-touring 6spd swap 7000$ obo
1981 Chevrolet Corvette (clean GA title)
$7000 or best offer
Engine/Engine bay
355 CI 330 HP (less than 20K on engine, still have the build sheet)
Swirl port truck heads – dual plane intake
.460 lift camshaft – 9.5:1 compression ratio (pump gas friendly)
Holley 600 (fresh rebuild)
HEI distributor
MSD 6AL ignition
New 85 amp alternator
4 core aluminum radiator
Electric fan – 195 on/180 off temperature switch
Electric in-tank fuel pump/sending unit from 1982 Corvette
Transmission
Borg Warner T-56 6 speed from 1995 Camaro
Built to hold up to 500 hp
F1 Stage 2 dual friction clutch
Keisler Engineering hydraulic clutch master cylinder kit
Custom driveshaft cut and balanced
Custom transmission cross member
Interior
Autometer ProComp II gages (RPM, Oil pressure, oil temp., water temp., voltage, fuel pressure, fuel level)
Switches for MSD and fuel pump
Suspension
New Monroe gas shocks
New bushings (sway bar, a-arms, trailing arms, strut rods…)
Brakes
New calipers/pads
New master cylinder/booster combo
Exhaust
Flowtech full length headers
Flowmaster 40 series dual exhaust
Miscellaneous
Rebuilt power steering
New rear tires
Needs
Paint
Interior
Front tires
Alignment
Old 08-23-2014, 08:06 AM
MathC3
MathC3's Avatar
That's what I call a sleeper !
Nice car, GLWS
Quick Reply: 1981 Pro-touring 6spd swap 7000$ obo
