FS: 1980 Corvette $12,995
Platinum Supporting Dealership
1980 Corvette Coupe-$12,995
1Z878AS431036
89,994 MILES
ORIGINAL 350 CI ENGINE, REBUILT AND STROKED TO 383CI (DETAILS ON ENGINE REBUILD BELOW)
2005 AUDI TT- GRAY PEARL METALLIC EXTERIOR
DOESKIN LEATHER INTERIOR
3 SPEED AUTOMATIC TRANSMISSION
CRUISE CONTROL
AM/FM STEREO WITH CASSETTE
POWER ANTENNA
DUAL REAR SPEAKERS
REMOVABLE GLASS ROOF PANELS
REAR WINDOW DEFOGGER
AIR CONDITIONING
HEAVY DUTY BATTERY
POWER WINDOWS
ALUMINUM WHEELS
COMPLETE NEW EXHAUST SYSTEM
NEW SUSPENSION BUSHING
NEW SHOCKS
NEW SPRINGS
NEW SWAY BAR LINKS
TRANSMISSION SHIFT KIT
LOTS OF NEW PARTS- PREVIOUS OWNER HAS LEFT US WITH ALL THE RECEIPTS AND PICTURES OF THE WORK PROCESS!
ENGINE REBUILD:
Block preparation (Clean, Boil, Bore, Hone, Cam Bearings, Soft Plugs, Machine Rod Clearance
Crank (Custom made 383 Crank, Clevite 77 Bearings, New Harmonic Balancer and flywheel)
Pistons & Rods (Ertel Cast Pistons, Flat Top, 9.5:1 CR, Sealer Power Molv Rings, ARP Rod Bolts, Resize Big End, Blance Asm.)
Camshaft (Wolverine Cam and Lifters, Cloyes Double Roller Timing Chain Roller Rockers, New pushrods)
Oil Pan (Melling High Volume Oil Pump, Pickup, Drive Shaft)
Heads (World Products S/R Torquer, 2.02 intake, 1.60 Stainless Steel Valves, "Z" springs, valve covers)
Induction (Weiand Action Plus Intake Manifold, Q-Jet Carb, Carter Fuel Pump)
Ignition (Existing HEI- Recurved with MSD module and coil, Plugs, HD wires)
Exhaust
For more information or pictures of this Corvette please visit: http://www.vanbortelchevrolet.net/1980Corvette
1Z878AS431036
89,994 MILES
CRUISE CONTROL
POWER ANTENNA
DUAL REAR SPEAKERS
AIR CONDITIONING
HEAVY DUTY BATTERY
POWER WINDOWS
ALUMINUM WHEELS
NEW SHOCKS
NEW SPRINGS
NEW SWAY BAR LINKS
ENGINE REBUILD:
Exhaust
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
moving to C3s For Sale.
All of our Corvette's are inside our Indoor Corvette Showroom and we will be happy to keep it stored for you until spring arrives!
