C3s for Sale/Wanted Private Classifieds: Used C3 Corvettes For Sale, Modified or Stock Corvettes, and Restored or Original Corvettes
1980 Dark Blue metallic
Old 08-31-2014, 08:27 AM
diehrd
diehrd's Avatar
Default 1980 Dark Blue metallic
1980 Corvette , Dark metallic Blue , very few left this color. This is not only fun to drive but can be driven every day. $13,500.00
VIDEO OF driving the car ... http://vid1294.photobucket.com/album...ps12ff2120.mp4
All parts are within a few years of being new and with 11500 miles or less then 1500 miles.
Composite rear spring
3.92 Ratio gears
Eaton posi
Billet carrier caps
Tubular cross member
700R4 performance built with 2500 stall and lock up controlled by a switch
True dual 3" exhaust with X pipe
1 7/8 XS Power custom stainless Steel headers 4 inch collectors and 3 inch outlets
ZZ4 short block with 11500 miles upgraded to ( ZZ465) at minimum 465hp / 440tq
GM fast burn aluminum heads
PAC nitrated spring up grade kit good to 650 lift
GM847 Performance Roller cam shaft
LS7 Roller lifters
1.6 Roller rockers
GM Single plane intake manifold
FAST fuel injection ( Supports 650 hp )
In tank electric fuel pump and sending unit
New distributor with MSD ECU
Accel coil MSD wires and Accel shorty plugs
Tall ribbed valve covers
New Spectra air cleaner
New radiator
Trans cooler
Water pump
Alternator
Breaks 100% tires and rims 100%
Interior redone to stock with new carpets
Dash rebuilt all gauges work perfectly
Have a complete Stereo system for it ( not installed )
T-tops shine
NEW custom hood
New front end paint entire car was painted 5 seasons ago and the car looks new
Frame mint , floors mint . Car is well worth the little I am asking. A/C removed and correct delete plate used.
Clean title
There will be no test driving , Serious people only , if you love the c-3 style you will fall in love with this one. YOU CAN DAILY DRIVE this car , take it on trips or just do cruse nights. I personally drive the car every day as long as it is nice out. Starts effortlessly idles mint and runs mint.
Old 08-31-2014, 11:53 AM
Mikeski
Mikeski's Avatar
Great looking vette and your asking price is incredibly reasonable. I see that the fuel injections system and air cleaner prevents and AC to be added to the car. Am I correct?
With the 3.92 gears and the engine upgrades this vette must really get up a go. Down load a video showing everything working and even a short drive would help with your sale. GLWTS!
Old 08-31-2014, 01:12 PM
diehrd
diehrd's Avatar
The air cleaner is not an A/C issue .. Currently I have a 14 inch drop base on her .. The A/C I never liked it. The car is for open air driving IMOP but if it was a hard top car ( vette or non-vette) I would have kept the a/c.
I got clips of it driving Ill have to find it..
Old 09-21-2014, 11:12 AM
diehrd
diehrd's Avatar
Bump
To 1980 Dark Blue metallic
Quick Reply: 1980 Dark Blue metallic
