WTB C3 White in PA,
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11
Where in PA are you? What exactly are you looking for?
I have a '76, L82, 4 speed. It's a low option car (no power windows or locks), but it does have power steering and brakes. It's a driver, not a show car. PM if interested.
Not in Pa., but if you are interested...
I have a '70 Top Flight Award, t-top, matching numbers, 454, automatic trans., ac, ps, pb, tilt-telescope column, electric windows, rear window defroster, 72.000 original miles.
I rebuilt the rear suspension and differential last year.
She was in the Alan Shepard Sub-orbital Flight 50th Anniversary in 2011 and Ed Mitchell (the sixth man to step on the moon) was riding with me!
If you are interested, please send your email and I will send the photos!
John
John
Hi, PM me if interested.
Car is in NJ
1979 Corvette White/blue, 61K miles. 300 HP.
This car has undergone a full mechanical rebuild in the last 2 years. Many parts are upgrades from the originals. Super clean chassis and undercarriage with Zero rust. The 180 HP original engine has been replaced with a 1994 LT-1 300 HP engine and a 4L60E 4 speed auto trans.
All the parts have been properly & professionally installed.
Here are the new parts in the last 24 months:
17" tires on Custom Rally style Rims
Entire Braking system: Master Cylinder /Metal Brake Lines/Calipers/Rotors/ Brake Hoses
Hi Torque Starter
Body Mounts
Front end fully rebuilt with a new oversize front sway bar
1982 Corvette full aluminum rear with 360 LBS fiberglass leaf spring.
Battery
Exhaust system
Steering Wheel
Front Carpets/Console Sides/Kick Panels
Windshield
This all cost about $6,000.
Mechanically this car is unbelievable. This is how these car should drive: Fast, powerful, tight and reliable. The next step for the car is to be painted.
Needs:
The headlamps do not go up: there are new actuators are in place, but the air control valves are MIA.
It could an alignment,it is just a little off. ( between modern 17" rims and the front end being redone, at some point it would be beneficial.)
The paint is dull and or faded.After you factor in all the brand new parts you are only paying like $1900 for the entire rest of the car
Car is in NJ
Hi Torque Starter
Body Mounts
Battery
Exhaust system
Steering Wheel
Windshield
Needs:
