76 Corvette, L-48 4 spd in WA
Sold 76 Corvette, L-48 4 spd in WA
Mahogany Metallic with 138,000 mi and factory 4 speed. I am the third adult owner. It was purchased in Seattle. At some point the original owner moved to central Washington (desert) where my insurance agent bought it. I purchased it from him in May of 2004 with 124,000 mi on it. There are receipts going back to when it was almost new. It had an average repaint 23 years ago. It does still shine and looks great but does have rock chips from years of use. Now has a GMPP 350HO with very low miles. I have the original motor, air cleaner housing, plug wire shields and carb which is included. Original motor does need to be rebuilt, head gasket started to leak oil into the cooling system. This is a great driver with about every thing rebuilt during my ownership. Everything works but the clock.
Factory options are as follows.
Paint: Mahogany Metallic
Interior paint: Buckskin
Interior: Custom leather
Original motor 350ci, 180hp
Trans: 4 speed wide ratio
Power windows
Air Conditioning
Power Brakes
Tilt-Telescope steering column
Power Steering
Heavy Duty Battery
AM-FM Radio
Tires: GR70 x 15
During the first 4 years, here is what I did during the winter months.
Interior:
New Al Knoch carpet, door panels, A-Pillars, upper dash, lower dash, center console, leather seat covers and foam, storage compartment lids
Rebuilt seat belts by SSnake-Oyl
New stereo and speakers
Insulation under carpet
Engine:
GMPP 350HO
EB RPM manifold
BG 650 dbl pumper Speed Demon
New MSD distributor
Flywheel, clutch, pressure plate, pilot bearing and throw out bearing
Hooker ceramic coated long tube headers
DeWitt aluminum radiator with dual electric fans
Flow Master series 40 mufflers
Alternator
Mini high torque starter
HVAC
New hoses, compressor, heater core
Transmission
New seals, bearings syncros, reverse light switch
Brakes
New master, booster, hoses, turned rotors, and rebuilt calipers
Front Suspension
Ball joints
Idler arm
Tie rod ends
A-arm bushings
Power steering hoses
New touring springs which dropped the vette about 1/2”
Rear Suspension
Complete trailing arm rebuild with bushings and bearings
Fiberglass mono leaf spring
4 KYB GR gas shocks
Strut bushings
Strut adjusting cams
Wheels are Torque Thrust II 16 x 8
Tires are BF Goodrich G-Force 255/50R16
Pictures are located here
http://smg.photobucket.com/user/sunc...?sort=3&page=1
Power windows
Air Conditioning
Power Brakes
Power Steering
Heavy Duty Battery
AM-FM Radio
Tires: GR70 x 15
Interior:
Engine:
GMPP 350HO
EB RPM manifold
New MSD distributor
Alternator
HVAC
Transmission
Brakes
Front Suspension
Ball joints
Idler arm
Tie rod ends
A-arm bushings
Rear Suspension
4 KYB GR gas shocks
Strut bushings
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
Gorgeous car! Best of both worlds with the original engine included and a beefy motor to enjoy in the mean time. It is exactly what I'm looking for! Too bad it is on the wrong side of the country. GLWS and bump for a beauty.
