Big scale `67 Corvette L-88 - The $3.5million car.
Thanks Sarge!
So here is the interior. Did I capture it?
I overlooked the fact that the real car doesn`t have power windows, so I had to raid the 1/12 Camaro kit for an extra set of roll-up window handles for the door panels. I also had to carve off the power window switches from the console, after it was already painted and detailed mind you. I also used a completely new method of doing wood grain on the steering wheel. I think it came out better then my previous method, which was a little to streaky. The appropriate label and tag were added, both printed from 1:1 labels.
Looks great! I can only see one little thing that I think could be done for just a tad more realism: paint inside the door handle chrome flat black. That is just a hole through the door panel for the handle to slide back and forth when in use.
What was your new method on the steering wheel?
Thanks jroc. I`m not sure how I missed that. Now I just need to figure out how to get the paintbrush in there to get at it.
For the steering wheel, I used a gloss brown base coat, than used a wide stiff brush to "dry brush" the lighter color. Before I used to use a small brush and sort of "draw' the wood grain on. It was much more streaky this way, and too much contrast typically between the two colors. I think the new way looks much more realistic.
WOW...I haven't done this sort of thing in years, and was never really good at it when I did - your craftsmanship is insane! Really, really nice!
Thanks again guys.
Ok, I think I am just about satisfied with the wheel. I have spent waaaayyyy to much time on these. Now to assemble and cast them. I think I will have to have them chromed, as the chrome spray plating isn`t quite brilliant enough. What do you think?
Great looking build!
Thanks for the great tips everyone! My life is in transition in a lot of ways, so I am struggling to find time to complete this project.
I am using both the 1/12 Monogram `67 Corvette kit:
and 1/12 Revell `69 Camaro kit:
The Camaro kit is a little more challenging and quirky than the Corvette (unless you are doing the crazy things I am doing), but it is still very rewarding:
#33
Yep, that is a window sticker printed from a scan of a real `69 Camaro window sticker. On my previous L-88, I think I had one on that as well. Since this one didn`t have one when it went across the block, I probably wont be adding one.
#36
I'm just going to say that I am flat out amazed by this. Honestly, I don't really believe what I've seen here is real, lol.
Absoutely insanely high craftsmanship here. I tried to make a copy of my old C6 Z51, and it didn't come out anywhere near as pretty as yours, despite my attempts to polish it to a shine. It's sort of shiny, but your models are like liquid glass.
I wish I had this sort of skill. I would make a model for my C6GS.
#38
I'm not really looking to have one made, but it seems like the sort of project that would be fun to do. It's unfortunate it's a project and that nobody makes a model of the GS.
#39
St. Jude Donor '13, '15
#40
I have always loved following your builds here on the forum. I am just amazed at the craftsmanship of your work. I wish I had 1/10th of your skills as I have been building models for over 50 years and never acquired the skills that you have. Great Work! Thanks for posting your builds here on the Corvette Forum.
