1/18 display angle stands? Help Please.
Banned Scam/Spammer
Hi all, I have 3 Ertl 1/18 scale cars that I want to mount up on a wall. Anyone have a source? I was thinking something like a clear plastic piece angled with mounting holes, however open to other styles if not? Thanks for any help or links!
You might be making things way too hard for yourself. If you do not want the case there is a super simple way to do it. Take a look under the model and you will see the suspension A arms. I insert a 2 1/2 inch nail in the wall such that the nail "snags" the inside of the front upper A Arm, in effect hooking it. For the rear I either do the same thing or simply use a second nail such that the inside of the upper rear tire rests on it, so that you get the angle you want. The front is more than enough to secure it. This is a bit difficult to describe but is super simple. I have probably 50 mounted like this and in 30 years never had one come down. I will try to take and send pictures.
Banned Scam/Spammer
