shifting problem when racing
St. Jude Donor '05-'08
I posted this in C5 Tech,b ut since it only happens when I 1/4 mile race I thought maybe someone here knows whats up:
Since I went with the H/C package and also changed over to the C6 shifter I have noticed a problem shifting gears when racing at the 1/4 mile. At Pocono Long track I had no issues, but since last night was the 2nd time I ran the 1/4 since the Mods and had an issue I wonder what is up.
Here is the scenario:
I run a few runs with no issues. I get good shifts and everything is fine. I then get to about the 3rd run and I start to miss 2nd gear. I just cannot get it into gear.
Last night something new happen during the 5th run. I got my shift into 2nd, but I swear I could not move the shifter into 3rd. It was locked there. The clutch was in, but it would not move. Thinking about it over night I am not sure if it was locked in 2nd or stuck between 2nd and 3rd, but I know I could not move it. I then pushed teh clutch in a few times and it went into 3rd with no problem.
I stopped after that and let the car rest for about 1/2 hour. I drove home with no issues being able to shift into all gears though I could not really run the gears to see if there was an issue.
Just wondering if it is me, the shifter, something else that is starting to go, maybe time for a new tranny, syncros are out and when they heat or at high rpms they have problems (high rpms would explain why I don't have issues at the road track - I assume heat wise it would be hotter at the road tracks).
Any ideas???
Any ideas???
after upgrading from stock clutch (peddle stuck to floor) similar thing happened to me...speedshop added spacers to new Ram clutch assembly (external) and after several more test and adjustment problem "mostly" fixed....
Any ideas???
Any ideas???
You don't have problems on the road because you are shifting easier.
Maybe I can help you tomorrow at the track rental.
bob - I am thinking the C6 shifter is causing the problems, but I am just not sure. I might take the whole thing apart again and see if it is aligned right.
Maybe I will just go by the hurst shifter and test that...
thanks
BTW - I will not be at the rental tomorrow - I have a $236 million budget to finish up....
thanks
thanks
thanks
I would bet money that the shifter is the problem.
Originally Posted by cyclerage23
WHat clutch are you using? Do you still have the stock clutch master? I doubt the shifter is the issue.
I have the RPS clutch. I dont think the clutch master was touched when I changed it over...
Bob, take out the shifter, especially if YOU did the install!! LOL
This is the easiest thing to eliminate...When my trans went the 2nd time, I had similar issues but even when doing low rpm driving....
I'm leaning towards trans! Sorry! Could be synchros &/or trans gears shot...What does Chris say??
Ron
PS- How'd ya run last night?
Ron
We're having same issue with Rich's car (same clutch). You either need to shim between the slave cylinder and pressure install an adjustable master.
I'll bet you clutch pedal grabs really close to the floor, right? Maybe 1/4 of the way up?
I think it grabs closer to the top with normal driving. Under hard driving I have no idea. I guess I need to take more notes...
Does his car also act ok the first 2 runs or so?
When the fluid gets old it gets spongy and wont engage the slave cylinder all the way. Ask Chris if the flushed the fluid when they did the clutch.
Ron
I believe we did switch the fluid. I remember seeing it done.
BTW - I called Chris and he said he read the thread and wants to put in something - pressure pad maybe - dam I hate when I forget when someone says something to me. He explained what he believes is happening and it made sense to me.
He said it is not hard to install so I will get it done one night next week and give my feedback...
thanks
thanks
Is that like a tampad?
Jason I am not sure. When I get down there I can fill you in. It is going to be a busy week getting ready for the WGI run. I think I might even need new brake pads.
Boy racing is expensive......
Originally Posted by Special K
So finish it today and fix it Monday.
funny thing is we will be fixing it on Monday and Tueday and Wednesday and ......
funny how companies really check your numbers when you ask for $236 million....
