DragVette????
DragVette????
I'm considering buying a 420 hp 355 for my pretty-much-100-percent original '79 (TH350 tranny). Would the Dragvette suspension kit keep rear end parts from breaking? Would it keep the car off the walls? The car will see the 1/4 mile about four or five times a year. I'll probably run drag radials; definitely not slicks. Thanks in advance!
yes, the drag vette system will help a lot, keeps you out of that negative camber change on the leave...the 'squat' you see. It is a great product, I use it in my 67 with a 540. I am not sure you will actually need it though, with an automatic trans and street gears. Just my thoughts.
Just keep the half shafts as straight as possible, (get adjustable spring bolts to adjust ride height) make sure your rear spring is not too soft, you can add a set of QA-1 adjustable rear shocks set at the stiffest level when drag racing to keep the car from squatting too far. With the 355 and horsepower your making you won't break anything except weak or worn parts. The car will dead hook and go straight as an arrow with a drag radial, no swaying or squirming. If you think you need a good set of spindles or axles get them from International axle. They are the best stock size replacement axles you will find, they are stronger than the GM's by far. I run fiberglass springs from Vettebrakes 360 or 420lb rate, QA-1's, solid u-joints, eaton posi, the big aluminum discs that hold the crossmember up, My 75 vette runs 11 teens @ 119mph with a glide and 4000 stall converter. 1.60's sixty foot times on footbrake leaving at 2,000 rpm with no issues. I even hit at 3500 with the trans brake and it won't break. Good Luck and enjoy, I run the Corvette Challenge in NJ 12 times a year plenty of C3's running with stock rear's and auto with no issues.
Dragvette will work nicely...I have it installed on 2 different 69 vettes I have owned. I snapped the outer spindle and Dragvette saved me big time from having a half shaft rip everything else apart.
Because you are using a auto trans and its only 420hp it will be hard to put a lot of "shock" stress on the drive train even with drag radials. First I would do the "solid spicer" joints then consider the dragvette kit.
Received 1,762 Likes
