From Mobil 1 to Royal Purple = spun bearing(s) - coincidence?
A little over a year ago, I spun a bearing on my initial build on my 406. I was running Mobil 1 for a while and later switched to Royal Purple... The car did go faster with the Royal Purple but after a few passes, I spun the bearings...
I did the same thing again on my current build.. I used Mobil 1 0W40 for a while and switched to Royal Purple 10W40 in December. Again, the car ran faster with the Royal Purple but after only 10 passes with Royal Purple, I spun the bearings again.. However, I also started running nitrous which might have had something to do woth the spun bearings too..
Has anybody heared about similar experiences in going from Mobil 1 to Royal Purple with a drag race setup?
Ollie, can you be more specific on which RP you were running?
at that weight I would say coincidence. Although I would take a look at the Joe Gibbs oils, as we are having VERY good luck with it. www.joegibbsracingoil.com
I personally also think that it's coincidence.. but you never know. I went to Royal Purple as it gives me a few hundreds at the track.. I used to run it for over a year in my old 383 without any issues... I don't think that IF the oil caused the problem it's not because of the oil itself but due to the change from one oil to another.. Maybe there is something that makes them incompatible.. Maybe I should go back to dino oil for a few runs and then use Royal Purple.. At less than 7000 RPM, I shouldn't need higher than a viscosity of 40.. Your stocker revs a lot higher than that
Same rods? Rebuilt after the first time?
Ran both oils no problem, now running strictly M1.
I'm sure you've checked it but be double sure you've got enough bearing crush.
Bad timing for the NCC, I was looking forward to seeing you run, maybe next time.
Good luck,
Dave
Good luck,
Dave
There is a small <5% chance that I'll still make the national race.. I found a 650 HP 410 Cubic inch small block (with callies crank and crower rods) for sale (never run as it was a racers backup engine) but I don't know if it's still available.. E-mailed the seller and haven't heared back.. If I could have that engine delivered until early next week, it could be in by Thursday next week.. However, I doubt that the engine is still available...
I'd like to see your car run too!! We will see.. maybe a miracle is gonna happen
I would stick with Mobil 1. G.M. has put it in the new vettes for almost 20 years. I think they probably have done more testing than we could ever hope to do. Plus the fact that R.P. IS cheaper, look at the money they would save..They use Mobil one for a reason.
R.P is actually $1 more expensive than Mobil 1.. I paid $6.99 per quart for Royal Purple...
I buy M1 at Wally Mart in the 5 qt. jug, approx.$18-19 per, sometimes even less on sale.
Recently tore down the green car engine out of quilt, after many years of running it hard the bearings & pistons looked perfect! Could have been looking at pieces from an engine with 10 runs instead of one with 1000+ passes.
When the pistons decide to come back from shipper h3ll, you can bet after breakin there'll be M1 in the pan again.
Dave
Dave
Dave
Dave
The question is if it would've looked just as good with Royal Purple???
As I said, I ran Royal Purple in my old 383 and had no issues.. 20000 street miles and many drag strip passes..
Cruising
I have ran royal purple for years in my race car and street car(Motor & Rear end). I put over 200 passes on my car last season and have had no problems what so ever. Everytime I pull the motor down the bearing still look like new.. I would recommend royal purple to anyone!!!
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Royal Purple is good stuff. But there is a huge difference in street use RP and the real race oils.
I've seen a circle track motor survive lap after lap with literally no water in it (blown head gasket) and pulling into pits to *top it off* while running when under a caution and then going right back out on track. Temp gauge pegged just off the steam!! We would have sworn the engine would be dumpster bait...but during teardown we were amazed to see pistons, cam etc all perfect. Head was missing a 1" chunk between cylinders..but rotating parts including bearings were fine. Who knows what oil temps got to in that thing!! Takes a special oil to keep something like that going.
But again..this was race RP..not normal street stuff. We've also used the super thin race RP for qualifying and setting records..but it's about a one pass deal at the track..gets a little expensive. Plus you get nervous seeing oil pressure gauge almost on *0* at idle and only 40-45psi at 9000+ rpm!!! But it works!!
I was using regular street RP at BG last summer.
JIM
JIM
