MT ET Street Radial II vs ET Street which hook better?
I'm looking at MT ET Street Radial II 28X11.50R17 vs the ET Street 26X11.5X17 anyone know which will hook better? I have a 2007 Z51 MN6 around 600 whp (ECS SC 15 psi). I was thinking that the Street Radial would hook better because of the hight therefore effectively increasing my gear ratio.
on both accounts. smaller tire= higher gear ratio, bias hook better than radial, but I have heard a lot of good things about the radial.
I meant decreasing the number increasing the length of gears. I'm guessing it must be sucky track prep then. I just don't understand why they don't make ET Streets in 28 inch.
You will get a better 60' with a shorter tire than a taller tire - assuming traction is the same.
They do make ET Streets in 28", unfortunately just not in 17". 28 x 11.50-16
My info:
My consolidated list of personal stock
Wheel size,type, & weight in lbs ea
OEM MAG 17 x 8.5, 17.5
OEM MAG 18 x 9.5, 19.5
OEM MAG 18 x 9.5 w/ new Yoko 295/35-18 AVS sport non-runflats, 50
OEM MAG 18 x 8.5 w/ new Yoko 275/35-18 AVS sport non-runflats, 46
PWO 5 spoke Y2K repos 17 x 8.5 +58mm, 20
PWO 5 spoke Y2K repos 18 x 9.5 +65mm, 23
HRE 18 x 9.5 545 w/ clear center +58mm, 22
HRE 18 x 12 545 w/ clear center +74mm, 27
PWO 17 x 8.5 +58mm w/ oem runflat 245/45/17 (8/32 tread), 50
PWO 17 X 8.5 +58mm w/ new MT ET Street 26 x 11.50 x 17 with TPS & lots of weights, 45
OEM MAG 17 x 8.5 w/ NITTO 555 275/40/17 (1/2 tread), 45
OEM MAG 18 x 9.5 w/ stock OEM 275/40/18 runflats, 53
OEM MAG 17 x 8.5 w/ stock OEM 245/45/17 runflats, 47
OEM MAG 17 x 8.5 w/ new MT ET Street Radial 275/40/17, 47
OEM MAG 18 x 9.5 w/ new Hoosier R3S05 275/35/18 road race radial 4.5 32nds tread with std valve stems 42
CCW drag pack rear 16 x 10 classic full polished with well worn MT ET Street 26 x 11.50 x 16 (1/32 tread) with center cap, 34
CCW drag pack rear 16 x 10 classic full polished with 1/2 worn MT ET Street 26 x 11.50 x 16 (3/32” tread) with center caps, 38
CCW drag pack front 16 x 5 classic full polished with like new Firestone deluxe champion 5.00/5.25-16 (10/32 tread) with center cap, 33
OEM runflat 275/40/18 worn to wear bars, 29
Bridegstone expedia S-01 345/35/18 (9/32 tread), 37
New MT ET Street Radial 275/40/17 (6/32 tread), 30
New MT ET Street Radial #3784R P315/30R18 26X12.50R18 (6/32 tread), 28
New MT ET Street 26 x 11.50 x 17 tires (6/32 tread), 25
MT ET Street 26 x 11.50 x 16 tires worn out (1/32” tread) 15.75
MT ET Street 26 x 11.50 x 16 tires (3/32” tread) 18
OEM runflat 245/45/17 (8/32 tread), 29
BFG G-force drag radial 345/30/18 new, 30
BFG G-force drag radial 345/30/18 1/32nd, 29.5
BFG KDW2 295/35/19 new, 32
Yoko 295/35-19 AVS sport non-runflats (2/32 tread), 29
Toyo Proxes RA1 335/30ZR18, new, (8/32 tread in the middle & 6/32 outside edges), 33.2
Topline 5 spoke Y2K chrome repos 18 x 10.5 +58mm offset rims w/ new MT ET Street Radial #3784R P315/30R18 26X12.50R18 , 58
Topline 5 spoke Y2K chrome repos 18 x 10.5 +58mm offset rims w/ new 275/35/18 BFG G-force TA drag radial, 53
Bob' House of Wheels 18 x 10.5 Chrome Y2K repos widened to 18 x 12. Work was done by Weldcraft Wheels.+56mm (with the 1.5" strip inserted, they should be right at 9.375" backspace, 31
HRE 18 x 12 545 w/ 345/30/18 BFG DRS, 57
HRE 18 x 9.5 545 w/ clear center +58mm w/ new 275/35/18 BFG KDWs, 52
HRE 18 X 9.5" 545 full polished w/ Yoko 265/35-18 AVS sport non-runflats (8/32 tread), 50
HRE 18 x 12 545 w/ 345/35/18 EXPEDIA S-O1 (9/32 tread), 64
HRE 19 X 10" 545 w/ Yoko 295/35-19 AVS sport non-runflats (5/32 tread), 58
HRE 19 X 10" 545 w/ new BFG KDW2 295/35-19 (10/32 tread), 61
HRE 18 x 12 545 w/new Toyo Proxes RA1 335/30ZR18 & TPS, 58.4 lbs
My best 60' times on my 97' 4l60E A4:
New MT ET Street Radial 275/40/17 on C5 OEM 17 x 8.5 Magnesium wheels = 1.47 60'
Worn out 26 x 11.50 x 16" Mt ET Street on a 16 x 10 CCW drag pack = 1.51 60'
New 26 x 11.50 x 17" Mt ET Street on an PWO Y2K 5 spoke 17 x 8.5 = 1.53 60'
1/2 worn (3/32” tread) 26 x 11.50 x 16" Mt ET Street on a 16 x 10 CCW drag pack = 1.53 60'
1/2 worn 345/30/18 bfg dr on HRE 545 18 x 12 wheel = 1.49 60'
I have over 400 passes on these set-ups together and at different tracks....
And once I get my 01' stick dialed in tune wise...........I will be able to compare that as well
I didnt see it on the tires/wheels in a Bottle list so:
NEW-BFG Drag Radial 2 275/40R/17 27.5 lbs
OEM C5 Z06 17x9.5 front wheel 19.1 lbs (Speedline)
OEM C5 17x8.5 front wheel 22 lbs (Wagon Wheel)
No Dave, you are fast! I was only alluding to the following:
C5 Z06 External/Internal Bolt On times (stock cubes, n/a, cams, h/c, all bolt ons)
1---9.985 @ 138.80--1.428 --robz ---------'03 04/08 -----H/C, ET ST, Gears, Post 328, Slip
C5 Z06 External Bolt On Times (stock long-block)
1--10.890@125.06--1.465--GARY2004Z06--'04 12/08-VR CAI, DRs, ARH LTs, Clutch, Gears, Post #356
I know both of these guys run DRs.
I saw the C5 Z06 Fast List......stock class, stock-cai/dr's class, and of course yours. What makes the C5 Z06 so stinking faster than the regular C6 with similar hp? I know DA has some to do with it (been to MIR myself ) but I still was amazed at the times. I had to put on cai, headers, tune, dr's to manage a 11.79 with my C6 A6 at MIR.
And who holds the record for the stock fastest longblock + power adder (just so happens to be a 6 speed too)? 10.12 @ 136 1.44 60' on ET Streets
Just playin Gary.... Actually, I have not tried DR's. Maybe I should
ATNB, you don't count since you're an auto guy.
Siffert - C5Z weighs less than a C6. Different gearing too.
