LG Motorsports G2 Coilover Kit-FREE SHIPPING!
Supporting Vendor
St. Jude Donor '11
NEW 2016 G2 DESIGN!
No better Coilovers for under $4000! These units (G2 Coilovers) are some of the best on the market and what LG uses on their World Challenge Race cars. Shocks are made Bilstein and each shock is spec'd and custom made to your needs! The G2's work great for street and track.
If your looking for a great street setup... LG offers the GT2 Adjustable Coilovers for your C5 and C6.
0% financing for up to 1 year available on all LG Motorsports products purchased through TPS! Free shipping to any address in the continental USA
Drag Racing versions available also
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
Supporting Vendor
St. Jude Donor '11
NEW 2016 G2 DESIGN!
Supporting Vendor
St. Jude Donor '11
Our G2 coil over suspension line started in 1993 on the 4th generation Camaro's and continues to this day with our latest design for the 7th generation Corvette. The G2's have won countless times in both pro and regional classes in autoX, road racing, and drag racing alike.
What has been at the core of all of the G2 packages has been our long running relationship with Bilstein Motorsports in making parts and designs to meet our needs and our customer's demands in performance and quality.
For 2016 we have a shock update that is going to make this package even better with little to no impact on pricing (to be released in January).
Our current G2 shocks
New G2 shock for 2016
New shock end cap
This is going to be the new shock that is supplied with all kits that will phase in during 2016. You will still have LG Motorsports proven mounting kits and top quality HyperCo springs going with each G2 set, along with our custom valving per your order.
What is new is a fine threaded shock body that will give the end user more accurate adjustments when corner balancing the car. Also new is a threaded on end cap protective cover for the floating rod guide. This acts also as a bump stop caps for those cars that require bump stops when needed. This new cap will help keep debris and dirt from the guide as well for longer service life.
This new modular design is also slightly lighter than the prior generation shock too, which is an added bonus! Total car sets will be about 1/2 lb lighter than last generation.
WHAT CHANGES
WHAT STAYS THE SAME
Of course LG will always support older generation G2's as long as we possibly can. This new design does interchange shafts and pistons so rebuilds can still be done on older designs the same as the new shocks.
LG Motorsports, always improving the breed through racing!
New shock end cap
WHAT CHANGES
- New fine thread collar adjustments
- Screw on rod guide / bump stop plate
- Screw on pressure chamber top
- Larger adjustment range
- Lighter weight
- Modular body design
WHAT STAYS THE SAME
- LG Motorsports custom valves per customer order
- LG Motorsports durable mounting kit
- Bilstein's patented floating pressure chamber design
- floating rod guide
- 46mm tube diameter
Supporting Vendor
St. Jude Donor '11
LG G2 Coilover
LG GT2 Coilover
LG G2 Coilover
LG GT2 Coilover
Supporting Vendor
St. Jude Donor '11
LG G2 Coilover
LG GT2 Coilover
Best Street Coilover on the Market!
LG GT2 Coilovers have been installed and used on 1000's of C5 and C6 Corvettes for almost 10 years. If your looking for a great street setup the GT2 Adjustable Coilovers is hard to beat for the price!
LG G2 Coilover
LG GT2 Coilover
