S. Fla PBIR 1/4? Weather Looks Great
#42
Last year when I ran my fastest time the humidity was 34%...super low dew point for us. That's the key it seems of the DA calc...we get 50's maybe 10 times a year, but low dew point, that's a lot harder to get!
I just got off the phone with my buddy Arnold who lives right by MIR. I need to go up there and make a run or two to see what my car can really do.
#43
i did get a new best but not enough to post on the fast list (10.92 spinning). i had 3 runs, spinning a little on every run but still got some ok 60's.
1st run
60'......1.56
1/4.....11.04
mph...121.9
2nd run
60'......1.54
1/4.....10.94
mph...122.2
3rd run
60'......1.52
1/4.....10.92
mph...122.1
not real sure why my mph was low with the good weather we had but i was expecting about 124 or so, o well ill get it figured out some time.
1st run
60'......1.56
1/4.....11.04
mph...121.9
2nd run
60'......1.54
1/4.....10.94
mph...122.2
3rd run
60'......1.52
1/4.....10.92
mph...122.1
#46
Received 2,045 Likes
1st run
60'......1.56
1/4.....11.04
mph...121.9
2nd run
60'......1.54
1/4.....10.94
mph...122.2
3rd run
60'......1.52
1/4.....10.92
mph...122.1
1st run
60'......1.56
1/4.....11.04
mph...121.9
2nd run
60'......1.54
1/4.....10.94
mph...122.2
3rd run
60'......1.52
1/4.....10.92
mph...122.1
#48
#49
Check out their you tube page...that thing is always wicked on shifts. Looks to me like they are running 5 psi or have something loose in the rear panhard bar!
In person it's amazing to watch..you always think he's not gonna make it....but that dude has ***** the size of bowling ***** and stays in it.
#50
yes i did and i had alot of knock due to my exhaust hitting a heat shield. for the last run i unplugged the sensors and copied the high octane timing settings to the low octane table and still had a low mph. when i scan it with the sensors unplugged it shows im getting my 26* timing without knock of course but my mph is still low. im going to fix my exhaust problem soon and see if it makes a difference with no knock and sensors plugged in. besides the knock everything else looked good.
#51
Perfect, that will work.
I bought a new computer (windows 7) and I am now having issues. My wideband would work for a few seconds and then flatline thru the run. I would re-calibrate per their site and it would still wack out. Now the program (or chord) is not working at all. I still have one old laptop if I can get the chord issue\wideband worked out.
#52
Or if you are using 2.2 you need the version that doesn't check for Net 2.0. Search their forum for "no LC" version of the software.
#53
You should contact Bill at Hp tuners. You might need a new beta. I was having trouble getting a scan, it would say service traction system, gauges would stop, etc. The new beta is perfect.
