Cool product for you drag racers!
Supporting Vendor
There's a lot of benefits to keeping your C5 Vette cool in the Drag seen!
The CoolIt! is great for cooling down between runs while sitting in the staging lanes and even after the burnout you'll be running Cool to make your next pass!
Here is SacCityCorvette’s latest version of the Cool It v2 and v3 Remote High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6.
Now you can control your C5 Corvette's radiator high speed cooling fan with the simple push of a button on your wireless FOB, allowing you to control your radiator coolant temps. No need to pay for a expensive tune to change your fans on/off temperatures or running you’re A/C to cool the engine, along with all the unnecessary wear and tear and fuel mileage loss that goes along with running the A/C.
The Cool It v2 and v3 now run on their own circuit and will not interfere with the normal computer controlled operation of your cooling fans.
Installing the Cool It v2 and v3 is a very simple five minute plug and play installation. (See our installation video) After you install the Cool It v2 or v3, you will be able to turn on the right side cooling fan on in high speed mode using a wireless FOB making it perfect for when you are at the track and you want to cool down between runs, in traffic and idling in parades. It will even help keep your Automatic Transmission running cooler too!
Preseason price is only $99.95!
Watch our installation video and see how easy it is to install the Cool It!
http://www.saccitycorvette.com/Cool-...sll-video.html
Here is a link with more information!
http://www.saccitycorvette.com/COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Can you/I turn on the fan with the engine OFF...
I have an electric water pump, and after a run park it in the staging lanes.. turn on the electric water pump, then also turn on the fan with the engine OFF I have seen some of my friends get their engine from 200 deg right after a run to 150 deg in 5 min by running the electric WP/ and Fan with the engine OFF...
Supporting Vendor
Hi jpee,
Yes, you can turn the fan on with the engine off but the key need to be in the ON position.
BTW, we only have CoolIt's for C5's at this time, but are working on a C6 version.
Jpee, I have one on my car...this would be the "cats meow" for you...I hope they get one for the C6 soon I may put one on my 09 as well. I'll show you at the track what it's like...like I say...you will love it.
Its made by Casper electronics... I'm going to see if I can hook up a small red light to it so if its on the red light will stay lit.. I'll mount the red light right on the console..
Supporting Vendor
Warm weather is coming! Your Vette will appreciate having
a CoolIt on it!
a CoolIt on it!
Supporting Vendor
Supporting Vendor
Midweek bump!
Supporting Vendor
The CoolIt will help keep your automatic trans cool too!
