Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Trailering C5
Old 04-11-2013, 09:25 AM
BIGMAC
BIGMAC's Avatar
Default Trailering C5
I am about to purchase an open aluminum trailer to haul my C5. This will be the first time using a trailer so help for a novice will be appreciated.
It seems the consensus from the forum is to tie the car down using "T" hooks placed in the frame jacking puck slots. I have two questions.
1. Could someone send a link to purchase the correct T hooks?
2. Using the T hooks and the trailer bed "D" hooks do you cross the tie downs?
Pictures of a C5 tied down to a trailer using T hooks would be appreciated.
Thanks in advance.
Old 04-11-2013, 09:40 AM
ZZOOM06
ZZOOM06's Avatar
Thanks in advance.
I got my T-hooks from AWDirect, just google them, and yes I do cross the tie downs. I use 8' long ratchet straps that I also got from AW.
I have an 18' Kwik-load trailer. Hope this helps.
Jimbo
Old 04-11-2013, 10:12 AM
mdaniel
mdaniel's Avatar
I use the Pierce Arrow Towing T-Hooks from Northern Tool:
Link --> http://www.northerntool.com/shop/too...-_-1206-_-CONF
I cross the rear tie-downs.
I don't have any pics handy, but I don't think a pic would help much.
I use the same procedure with both my C5 and C6 and it's much easier than using axle straps IMO.
Find someone local with a Vette who has towing experience to show you how to get your car loaded/tied-down properly. It's not particularly difficult, but if you don't know you don't know - and I definitely didn't know when I started towing.
Which part of FL are you in? I'm sure if you post up in the regional section someone would be happy to give you a hand.
Old 04-12-2013, 08:37 AM
Fuzzy Dice
Fuzzy Dice's Avatar
Cruise-In IV Veteran
Check your PM's...
Old 04-23-2013, 08:44 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
R hooks
Old 05-01-2013, 07:54 AM
REDC4CORVETTE
REDC4CORVETTE's Avatar
I just used a jacking strap on all 4 wheels ,just wraped it over the slicks at the rear over the top of the tire and pump the tire to 14 lbs and a cross over for the front to hold the skinnies .These cars don't like the body to be crushed down on the suspention for long runs.I blew the shocks that way once.Especially if you have QA1's
To Trailering C5
Quick Reply: Trailering C5
