Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
MIR WCF All Motor Class New Rules Coming Out
Old 08-27-2014, 09:51 PM
GARY2004Z06
Support Corvetteforum!
GARY2004Z06's Avatar
Default MIR WCF All Motor Class New Rules Coming Out
Just got off the phone with Jason Miller. Since GM is not represented in this class, we thoroughly discussed how we can get cars involved. The new rules are to be out soon. (I'll keep everyone posted.) In a nut shell, we are getting a break with weight reduction. This is huge for all of us wishing to compete. The LS1 & LS6 cam only crowd will get the biggest break. The bolt-on only LS7 guys and gals will be 150 lbs. heavier. LS2 and LS3 cars will fall somewhere in between. Please let us know if you have any interest in running to put on a good show for the crowd and represent.
Who knows, maybe we will get to eat some rice.
Old 08-27-2014, 10:50 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
As Gary said, this is huge for us LS guys.
Last year there were no LS powered cars in the all motor class. Gary and I both sent Jason an email with some suggestions. Jason told me he got more rules suggestions for the LS/all motor class than all the other classes combined. So, clearly the racers are there. Just none of felt we could compete with the rules the way they were.
Now, things have changed.
Rules will be posted Sept. 1st. Not likely until later in the day though.
This is a great event. Some class changes and rule changes will make this a smoother event than in years past.
Please consider going to this race to represent the LS race community.
Old 08-29-2014, 10:03 PM
boogieman
boogieman's Avatar
Interested...
Old 09-01-2014, 04:11 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
Here's a link to the rules posted today.
All Motor
http://www.importvsdomestic.com/rule...r_domestic.pdf
All rules for 2014
http://www.importvsdomestic.com/rulebook/
Old 09-01-2014, 08:14 PM
GARY2004Z06
All Motor
All rules for 2014
Thanks Pete.
Quick Cut/Paste for those who need to get a snapshot.
Here you go.
2014 ALL MOTOR
2014 WCF RULEBOOK ALL -MOTOR (DOMESTIC)
POSTED 9/01/14
M A R Y L A N D I N T ' L R A C E W A Y W O R L D C U P F I N A L S Page 1 of 2
Class Designation: The class designation is: A/M
General Safety: All vehicles must conform with general IHRA safety rules.
Body: Any year vehicle is allowed. Lightweight components are limited to hood, front fenders, decklid, hatches, sunroofs, wings, ground effects, and bumpers only. Roof, Quarter panels, and doors must remain
steel. One-piece front ends are not permitted. No body parts may be removed during competition.
Chassis: All cars must retain complete stock chassis, floorboard, firewall, and frame rails. Notching of chassis for clearance is permitted. Aftermarket “K” members are permitted.
Suspension: All cars must utilize stock front and rear suspension and mounts. Aftermarket front control arms, rear control arms, and sub-frame connectors are permitted. Aftermarket struts and shocks are
permitted. Ladder bars, four links, and wheelie bars are prohibited on all cars.
Lights: Headlights and brake lights are required (one headlight may be removed for induction).
Windows: All windows must be OEM glass.
Interior: Stock dashboard and full interior from front seats forward is required (passenger seat may be removed). Aftermarket seats, gauges, and interior are permitted.
Exhaust: Muffler(s) are required unless vehicle is turbocharged. Exhaust may exit anywhere.
Electronics: Two-steps, data loggers, aftermarket ECU’s, and engine management systems are allowed.
Driveline: Aftermarket axles, ring and pinions, final drive, spools, and differentials are permitted. Other OEM or aftermarket center sections and rear-ends may be replaced only if is a direct bolt in. IRS suspension
cars may convert to straight axle only if it is a direct bolt in.
Transmission: Manual or Auto transmissions are permitted. Any style automatic transmission is permitted. Trans-brakes are permitted. Manual transmissions are permitted to use aftermarket stock-style clutchassisted
transmissions. Sequential transmissions are prohibited. Aftermarket bell housings are permitted.
Clutch: Three discs maximum (any type of disk material is permitted). Clutch must be manually operated by driver’s foot.
Shifter: Shifter must be H-pattern. Strain gauges are permitted. Air shifters are prohibited.
Fuel: Gasoline and E-85 permitted. Alcohol is prohibited.
Fuel System: Electric fuel pumps only are permitted. Aftermarket fuel cells are permitted, and may be mounted anywhere.
Oiling System: Dry sump oil system is only permitted if car was OEM equipped with a dry sump and car is using complete OEM oiling system.
Tires: Maximum size slick or bias ply tire is 28.0” x 11.5”. Any size DOT radial tire is permitted, except 315/60/15, 325/50/15, 295/55/15, or 295/60/15.
8-Cylinder Engines – Chevy LS series
Engine: LS1, LS2, LS3, LS6, and LS7 series blocks permitted. No aftermarket blocks are permitted. Internal engine modifications are prohibited except for aftermarket camshaft, hydraulic lifters,
valve train, and overbore (See chart below for max CID).
Description: This is a cam only class with bolt-ons.
Bolt-Ons: External bolt-on parts are permitted.
Camshaft: LS1, LS2, LS3, and LS6 cars are permitted to run any hydraulic camshaft. LS7cars must run OEM camshaft and OEM valve train.
Induction: Engine must be EFI. All OEM intakes are permitted. The only aftermarket intakes permitted are: BBK intakes, Typhoon intakes, and Fast 78mm, 90mm, 92mm, and 102mm intakes.
Cylinder Heads: Un-Ported as cast cylinder heads only, porting prohibited. Any valve job is permitted. No milling of cylinder head. OEM cylinder heads only are permitted with the following casting
numbers: 241, 243, 317, 706, 799, 853, 862, 8452.
Power Adders: Turbochargers, Superchargers, and Nitrous Oxide are prohibited. All nitrous bottles and solenoids must be removed from car and nitrous nozzles must be capped.
Driveline Block Cylinder Heads Max Displacement Car & Driver Minimum Weight
Straight Axle or IRS LS1 LS1, LS2, LS3 or LS6 heads 348ci. Max 2750 lbs.
Straight Axle or IRS LS6 LS1, LS2, LS3 or LS6 heads 348ci. Max 2750 lbs.
Straight Axle or IRS LS2 LS1, LS2, LS3 or LS6 heads 366ci. Max 2850 lbs.
Straight Axle or IRS LS3 LS1, LS2, LS3 or LS6 heads 380ci. Max 3050 lbs.
IRS Only LS7 LS7 heads 427ci. Max 3050 lbs.
* Manual transmission: Deduct 100 lbs.
* Cars with IRS: Deduct 50 lbs.
* Cars equipped with LS3 Heads: Add 50 lbs.
* LS7 cars equipped with aftermarket cam: Add 150 lbs.
2014 WCF Rules
Big weight reductions so we can finally compete.
Old 09-02-2014, 09:14 AM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
That's way to many rules to police.
Old 09-02-2014, 01:29 PM
4DRUSH
4DRUSH's Avatar
What was the winning Et pass couple years?
Old 09-02-2014, 04:45 PM
LSOHOLIC
LSOHOLIC's Avatar
Looks like a high 9/low 10 sec class.
9.75 won it last year.
Looks very fun !!
Old 09-02-2014, 06:06 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
All I need is a set of stock LS7 heads and I'm all over this class!!!
Old 09-10-2014, 10:45 AM
veneno
veneno's Avatar
that's why I stop going to the WFC all the rules it's retarded
so this is bolt-ons, cam only but an LS7 can compete in this class, ok
Old 09-10-2014, 08:58 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
Seems pretty simple to me. Pick your combo. Pick your weight. Go race.
Jason is giving us a nice weight break. It's time for us to show up and support this class. Even if we're not successful, it shows our dedication so maybe next year we can be competitive.
Some people race... Some people just sit home and bitch...
Old 09-10-2014, 11:30 PM
boogieman
boogieman's Avatar
Not sure I fit in any of the categories listed, my motor is stroked, I'm running trick flow heads....and the car weighs over 3000lbs
Who's going to this? last time I raced in the World Cup, I raced in the 11.50 Index
Old 09-22-2014, 07:50 AM
REDGAR
REDGAR's Avatar
Cruise-In II & IV Veteran
CI VI Drag Champ!
I am glad to see Jason making adjustments. I tried supporting this class for years and just qualifying was my goal and I did a couple times. Took a while for Jason to open these up but sadly, it may be too late as the class has gotten way too quick now.
If some of you can make it, it is a pretty big and exciting event.
Old 09-25-2014, 08:50 AM
2003VETT
2003VETT's Avatar
Location: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
last year I ran true street, and the guys at tech had no idea what the rules were. I had to tell them what my weight needed to be. They looked at NOTHING. I had to add weight to my car to run because I was honest. The year before, all they checked was my battery hold down . No helmet, no jacket, no bar, they didnt even look! Now, this year I need a diaper for true street.(which is a good thing) Ill be going, just not running true street, Ill do either 10.00 or 10.50.
Last year was a mess because of all the oil downs and weather. In retrospect, MIR did a great job with the conditions, however, when you're there, it doesn't seem like it!
Old 11-06-2014, 08:27 AM
REDGAR
REDGAR's Avatar
CI VI Drag Champ!
This is the weekend.
Who is in?
Old 11-06-2014, 11:49 AM
Tsab
Tsab's Avatar
Don't want to rain on anybody's parade, but, the rules heavily favor the imports. Its as if there are no restrictions for them. Good luck to all of those attending. Fry some rice
Old 11-06-2014, 05:33 PM
REDGAR
REDGAR's Avatar
CI VI Drag Champ!
Results say different Tom
To MIR WCF All Motor Class New Rules Coming Out
Old 11-06-2014, 06:17 PM
robz
robz's Avatar
Who is in?
Gary and I are here. Packed as usual.
They cut the test session short due to rain.
Waiting to tech in then back to hotel.
Old 11-06-2014, 08:36 PM
2003VETT
2003VETT's Avatar
See you in the morning...
Old 11-06-2014, 08:39 PM
robz
robz's Avatar
Sounds good.
Quick Reply: MIR WCF All Motor Class New Rules Coming Out
