Carbotech Brake Pads
Supporting Vendor
St. Jude Donor '11,'13
If you need a high torque pad that works from dead cold check out the following options for you drag racers. Also, these option will hold you at the line.
Carbotech™ 1521™
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY Road Course use.
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
Carbotech™ 1521™
Carbotech™ AX6™
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
We combine superior customer service, speedy delivery, and the highest quality pad on the street or track . We can also accommodate special orders for any of Carbotech's compounds. Contact sales@ampdautosport.com for more information or call 216-780-8825.
Supporting Vendor
Brake Pads Street or Track Amp’D autosport has plenty of Carbotech compounds ready to go. Take 5% off your order when using promo code z28 at check out or call us direct at 216-780-8825 to order. Pre bed option is also now available for all Carbotech brake pads. Looking forward to hearing from you soon. Please call or email us with any questions.
Direct link: http://ampdautosport.com/
