D.A.D.S Outlaw Streetcar Shootout
This race will be held at;
Quaker City Motorsports Park
Salem , Ohio
http://quakercitymotorsportspark.com/
MAY 9 , JUNE 13 , JULY 11 , AUGUST 8 , SEPTEMBER 12
, entry fees, and payouts to be determined.
Rainouts will be Sunday, the next day weather permitting.
QUAKERCITY’S OUTLAW STREET CAR SHOOTOUT
Featuring All Heads Up Racing
DADS OUTLAW LIMITED STREET
DADS STREET LEGAL OUTLAW
DADS MODIFIED STREET OUTLAW
DADS ON THE FENCE CAR CRUISE
DADS OUTLAW LIMITED STREET:
Front Suspension:
-Stock front frame rails and suspension required (direct bolt-on aftermarket control arms and bushing allowed).
-Rack and pinion steering allowed.
-Aftermarket struts and coil-over’s are allowed, so long as they bolt directly to the stock location.
-Aftermarket sub-frames must bolt to factory mounting holes.
Rear Suspension:
-Any type rear suspension is allowed.
Tires:
-Any slick tire up to 30” x 10.5” sidewall designation allowed. W tires are allowed. DOT tires up to 12.50” sidewall designation allowed.
Engine:
-Any engine combination allowed.
Transmission:
-Any type automatic or manual transmission is allowed.
License plate required (any plate, cosmetic only).
All cars must meet IHRA/NHRA safety requirements.
Drivers must wear the safety equipment required for the ET’s being run.
Format:
1/8 mile race
Heads Up
.4 Pro Tree -- courtesy staging mandatory -- no deep staging
All Run Ladder
Pro run order (1 vs. 16, 2 vs. 15 etc.)
Bye run goes to the fastest qualifier and then it will be based on reaction time.
Lane choice goes to the fastest previous pass.
DADS STREET LEGAL OUTLAW:
This class is meant for registered street legal cars. When you sign in at the DADS booth, you must show registration and have street legal plates.
-STREET LEGAL TIRES MANDATORY. Drag radials and ET street are allowed. Any size drive tires allowed.
-MUST BE COMPLETELY STREET. If your car is questioned of being actual streetable, then this class is not for you. No gutted racecars permitted to race.
Body/Interior:
-Full bodied street type car/trucks. Domestic and import allowed.
-Working headlights and taillights, this means headlights not fog lamps.
-No dragsters, roadsters, altereds, or center steer cars.
-Must be street appearing, no gutted interiors. Must have 2 front seats or 1 bench seat. Carpeted interior even if rear seat is removed. Factory dash or pre-approved dash pad required. Must have door panels.
-Racecar lettering on windows only.
-Must have stock style front suspension.
-No full round or square tube chassis cars.
-Full exhaust system required.
Electronics:
-No bracket racing aids, no throttle stops (electric or pneumatic), no optical sensors.
-No delay boxes permitted for starting line procedures or other driver aided electronics. The
application or use of any device, mechanical or electronic, that permit the driver to ascertain the
position of their vehicle in relationship to the starting line is prohibited.
-Progressive nitrous controller system is allowed.
-No electric or air shifters permitted.
All cars must meet the IHRA/NHRA safety requirements.
Format:
¼ mile race
Heads Up
All run ladder
Bye run goes to the fastest qualifier, and then it will be based on reaction time.
Be prepared to run round robin.
-Slick tires allowed, any size drive tires permitted.
Body/Interior:
-Factory street type cars/trucks. Domestic and import allowed.
-Working headlights and taillights mandatory, this means headlights not fog lamps.
-Must be street appearing. No gutted interiors. Must have 2 front seats or 1 bench seat. Carpeted interior even if rear seat is removed. Factory dash or pre-approved dash pad required. Must have
interior door panels.
-Racecar lettering on windows only, minor exceptions may apply.
-Back half or stock rear suspension allowed.
-Windows, lexan permitted.
- Full round or square tube chassis cars. Can not be certified past/faster than 8.50 certification.
-Exhaust system: mufflers mandatory.
-No gutted racecars permitted to race.
Electronics:
-No delay boxes permitted for starting ling procedures or other driver aided electronics. The
application or use of any device, mechanical or electronic that permit the driver to ascertain the position of their vehicle in relation to the starting line is prohibited.
-Progressive nitrous controller system permitted.
Format:
¼ mile race
Heads Up
.4 Pro Tree --courtesy staging mandatory-- no deep staging
All run ladder
__________________
"Its a Slow Ride without the OXIDE"
Salem , Ohio
Front Suspension:
Rear Suspension:
Tires:
Engine:
Transmission:
Format:
1/8 mile race
Heads Up
All Run Ladder
Body/Interior:
Electronics:
Format:
¼ mile race
Heads Up
All run ladder
Body/Interior:
Electronics:
Format:
¼ mile race
Heads Up
All run ladder
__________________
