The McLeod Clutch Sale is Back @ Hinson Motorsports
Former Vendor
-Lighter than stock pedal feel
-Bolts to stock factory flat flywheels (LS1/LS6 only)
-Easy Installation
-Organic & Metallic disc facing available for smooth & even engagement
-Smooth engagement with excellent release qualities
-Low Rotating Mass (moment of inertia) for quick revs
-Includes CNC machined and anodized flywheel adapter ring
-Blanchard ground floater with multiple straps to reduce noise for streetability
Balancing of you clutch and flywheel together to reduce vibrations is also available
McLeod RST Street Twin Disc 800HP <- CLICK HERE FOR PRICING
McLeod RXT Street Twin Disc 1000HP <- CLICK HERE FOR PRICING
McLeod Street Twin Disc & Flywheel 1200HP <- CLICK HERE FOR PRICING
* Comes with ARP Pressure Plate Bolts
Mcleod Billet Aluminum Lightweight Flywheel 14LBS <- CLICK HERE FOR PRICING
McLeod Billet Steel Flywheel 24LBS <- CLICK HERE FOR PRICING
Don't Forget your ARP Flywheel Bolts Or Your ARP Pressure Plate Bolts <- CLICK HERE FOR PRICING
HINSON Motorsports is a full line distributor of McLeod products. Use the "Search" function on our website to find 1,000's of McLeod products at www.HinsonSuperCars.com.
Former Vendor
Don't forget to check out other items you will need to pick up from out online store such as slave cylinders, as well as pilot bearings. All in stock and ready to send to your doorstep.
