Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Best 60ft to be had with factory C6 19x10 rear wheels (any tire)
Old 04-16-2015, 09:47 AM
JackLS1R1
JackLS1R1's Avatar
Default Best 60ft to be had with factory C6 19x10 rear wheels (any tire)
I bought my Procharged C6 with some bling-bling 20 inch rear wheels on the back. I put some Pierelli 305s on the back (had 285s). Car puts down 540 at the wheels. Best 60ft I could muster is a 2.0
Looking to put some stock size wheels on it.
What type of 60ft can I expect and what tire brand/type should I use?
Thanks!
Old 04-18-2015, 08:50 AM
GARY2004Z06
Support Corvetteforum!
GARY2004Z06's Avatar
Thanks!
We have used the MT ET Street Radials ( P305/35R19 ) on a stock C6Z wheel which is 12" wide. They would fit fine on a 10" wheel as you plan although the contact patch will be a little narrower. Coming out soft (3800 rpm), we have been 1.62 60'.
Old 04-18-2015, 03:14 PM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
Although a better tire/wheel combo will help your 60', a higher stall TC will make a bigger difference. Go for both and win big.
Old 04-19-2015, 04:53 AM
LS1LT1
LS1LT1's Avatar
You might also want to consider going to an even smaller diameter factory wheel such as the C5 Z06 rims in either 18x10.5 (rears) or 17x9.5 (fronts), the 17s fitting (offset etc.) on the back of a base C6 much better than the 18s of course.
The benefits there are cheaper drag radials (especially when going 17s) that will likely also hook better than 19s.
To Best 60ft to be had with factory C6 19x10 rear wheels (any tire)
Quick Reply: Best 60ft to be had with factory C6 19x10 rear wheels (any tire)
