Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
C5/C6/C7 Alky Control Methanol Injection Systems | JDP Motorsports
Old 05-05-2015, 11:46 AM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Default C5/C6/C7 Alky Control Methanol Injection Systems | JDP Motorsports
JDP Motorsports is proud to offer, use and install Alky Control Methanol Injections systems!
With the flood of Injection systems on the market today, A little research and you will notice that most if not all provide systems based on a 50/50 mix, This is due in part to the higher cost of internal as well as external parts needed to hold up to 100% "safely". A perfect example is type of hoses used.
When you purchase an Injection system from Alkycontrol your getting a product thats been tested time and time again by some of the fastest out there, be it cars, trucks, jet skis, airboats, and even a world record holding airplane. If it has a piston/rotor on boost, it will benefit from our injection system.
Alky Control - Methanol Injection System - 1997-2004 C5 Corvette - AK-C5-Kit
Alky Control - Methanol Injection System - 2005-2013 Corvette - AK-C6-Kit
Alky Control - Methanol Injection System - 2014-2015 Corvette - AK-C7-Kit
The Alky Control Methanol Injection system for the C5/C6/C7 Corvette features a boost referenced, progressive meth controller which automatically releases increasing amounts of methanol as boost increases. This progression ensures smooth and even fuel delivery so that the transition or power remains smooth all the way up to redline. Alky Control Systems use only the best components. Braided Stainless Steel Lines, a High Volume Methanol specific pump, sealed electrical connectors and brass fittings.
Methanol is a highly effective addition for your force induced car for a number of reasons. First, Methanol injection is a highly efficient chemical intercooler. By injecting methanol into the inlet of a supercharged car, intake air temperatures (IATs) can be reduced by more than 80% (depending on ambient air temperatures) and allow your tuner to run more timing and therefore making more HP. Secondly, Methanol burns at the equivalent of 110 octane fuel, effectively halting detonation that can be present with lower octane fuels. Methanol works to keep your engine cleaner, and helps remove carbon deposits that can form on the pistons, which can effective change engine compression and combustion properties.
Features
  • PAC Progressive controller
  • Modified pump (for methanol)
  • Stainless braided hoses pre-assembled
  • Complete Harness w/everything needed
  • 2 Bar GM MAP sensor with regulator
  • Includes Installation Instructions with Tuning Tips
  • 1 Year Parts and Labor Warranty
Options
  • Dual Nozzle for 650+ RWHP
  • GM IAT Sensor Upgrade with everything needed (Better and safer tuning solution*)
Starting at $599.95 Shipped!
ORDER HERE
Please feel free to call, PM or email us anytime with questions. Our Expert staff will be happy to assist you in choosing the best options to suit your application.
Best regards,
Tyler
888-308-6007
sales@jdpmotorsports.com
Quick Reply: C5/C6/C7 Alky Control Methanol Injection Systems | JDP Motorsports
