Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Rubber Removal
Old 06-17-2015, 10:53 AM
kromberg
kromberg's Avatar
Default Rubber Removal
What is a good method for removing rubber from fenders, wheel wells, underside parts, etc?
Old 06-17-2015, 12:14 PM
YO-EL
YO-EL's Avatar
get a kid.....
Old 06-17-2015, 07:31 PM
L79racer
L79racer's Avatar
On the paint I use WD-40 and a rag.
Old 06-27-2015, 01:26 PM
dogboy
dogboy's Avatar
Every time I work in that area( tire change, whatever) I scrap off a little more. Been doing it for past 2 years & still has a lot more to go. If I was to go hog wild I would use a rotary brush & some chemicals as mentioned. tough part is on mufflers.
Old 06-29-2015, 10:19 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
I let it dry and then use one of the wife's old kitchen pot scrubbers. The ones with the nylon mesh over a sponge. Trying to clean it while the rubber is fresh and filled with glue is not fun.
There were a few times I sprayed WD40 in the wheelwells while I was at the track and went to a carwash after racing, which worked fairly well. Then I missed it once and found the scrubber method.
I've even thought about making disposable snap-in liners.
Old 07-01-2015, 08:06 AM
dankhts
dankhts's Avatar
I usually spray a good amount of WD40 all over the affected area before the event starts then it washes off easily at the car wash after the event.....the best thing I found however is the foaming type of no touch tire shine.....spray the crap out of the whole area and it comes of with a hose afterwards...
Old 07-01-2015, 10:37 AM
kromberg
kromberg's Avatar
I am definitely good to give it a try this weekend. Thanks
Old 07-06-2015, 02:09 PM
kromberg
kromberg's Avatar
Wow, the WD-40 trick does do a great job of dissolving the rubber, but it makes a god awful mess to clean up. You get the sticky black goo on you anywhere is it is a long tome scrubbing to get off the skin.
Any good way to remove the rubber/WD-40 goo other than a huge amount of paper towles and a full body suit?
To Rubber Removal
Quick Reply: Rubber Removal
