cam only c6
cam only c6
base c6 ls2 small 228r cam tsp headers 3 in x pipe straight pipes out back car wen 12.12 at 118 mph on wide oval tires 30psi. everything else stock no stall no gears. still on stock 231 gear... spun a bit but not too bad.. chirps 2nd hard!!!
r/t.......126
60.......1.97
330.....5.29
1/8......7.95
mph.....92.73
1000....10.22
et........12.12
mph.....118.00
r/t.......126
60.......1.97
330.....5.29
1/8......7.95
mph.....92.73
1000....10.22
et........12.12
mph.....118.00
what do you guys think about the runs? had two others passes 12.23 12.22 117mph and 118 mph tuner told me it had 11.90s all day the day was hot and humid so hopfully with better weather ill be in the 11's
what street tires are you guys running i have heard anything that not run flat is good... how could i tell between run or non run flat tires...
Well Ive had mickey thompson street comps (300 treadwear) street tire and had good results. My cam only stalled ls3 went 11.6@119 (Best trap on those tires was 125). Now my car is bolt on with some cheap nankangs on some 20s and did 11.9@118.
