C5Z Heading to the track tonight.
Meyham 2 cam
Vararam intake
LT headers stock Ti exhaust
Nitto 555r's
Looking to redeem myself....
So my first time to take the car to the track was pretty lack luster. I was only able to get one run in and, as it was my first time down the track in this car, it didn't go as well as I would have hoped. 12.30 @ 118. 1.99 60 ft. After a fairly soft launch the car wheel hopped in second pretty hard - lifted - got squirlly in third - slight lift. And got a little loose on the 3-4 shift. The 555r's were at full street pressure (35 psi) as I wanted a true baseline. I wish this thing would have run the way it does on the street. Very little wheel hop, more stable on the 2-3 shift and no drama in 4th.
This trip I'll air the tires down to 19 psi. Going for 11's. I'll post the results.
Vararam intake
Nitto 555r's
Meyham 2 cam
Vararam intake
Nitto 555r's
Vararam intake
Nitto 555r's
10-94 (12-06-2015)
Meyham 2 cam
Vararam intake
Nitto 555r's
Vararam intake
Nitto 555r's
Went 11.749 @ 121.5. Track prep was better. My 60ft wasn't any better but being able to put the power down all the way through the traps really helps. 2nd gear still had a good bit of wheel spin although not near as bad as the first trip. third still spun a bit and fourth always gives a bit of a wiggle.
Here's how it played out
60ft - 1.895 - spun...
330 -5.090
1/8 - 7.639 at 96.33
1000 - 9.839
1/4 - 11.749 at 121.56
Time only allowed for two runs. The first pass the beams were not working for the 1/4 mile time but were running for the rest of the pass. Everything on that run was about the same as the run I just posted. All in all I had fun. Solid 11 sec car, full weight (2/3 tank of gas) 3490 with me in the car.
330 -5.090
1000 - 9.839
With a stick car you might do better with Bias Ply tires. Plus they are a little easier on the drive train. If you are planning to go to the track on a regular basis, you may want to invest in a Drag Pack either a CCW's or Bogarts. I ran ET Streets on my C-5 and my 60 ft times improved over the radials. You can find used Drag Packs for about 1500 to 2000 depending on age and condition.
I switched from radials to bias ply for the track and will never go back as long as I have a manual. Night and day difference. I have a lot more confidence in the drive train as well.
