Need help defining stock class
I am building a 1956 Corvette with a stock 265ci, 2-4s and I would like to know if anyone knows what letters I should put on the window if I were to run in the stock class in the late '50s-'60s (A/S, B/S, C/S etc.) or something else. After looking up some #s, I come up with 2730 lbs. (curb wt.) @ 240HP. Thanx in advance.
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Give them time... There are some very knowledgeable racers in here that will be able to answer your question, but they might not stop by every day.
If you want an answer right away, ask the question on YB. Or Classracer.com.
Go to the NHRA website JUNIOR STOCK CLASS. You will be able to enter in the data for your car,and then it will determine what the proper class would be.You will need excel in order to download the info. HOPE THIS HELPS.
