Will Hoosiers 28 x 17 bias ply fit a C5?
I'd rather see you run a 26 x11.5 ×16 Mt et street for now.
This as a bias ply tire and can fit on your c5 with minor adjustments if any. The 26" tire is easier on the drivetrain and clutch and just enough to hold your power with practice and some finesse. You'll need skinnies too. I can help you get a drag radial to work if you had to but your best off with the setup mentioned above.
Hey rob, it looks like my options are a 28x10 bias ply or a radial. My car puts out just over 600rwhp and 490 torque with a 6 speed trains and McLeod dual clutch. I was told by many to not run a radial but I see many guys do. I'd be devasted if I broke something. Plan for the car is to test n tune for fun and maybe run one class this summer once a month. Car has upgraded output shafts and stronger tranny parts. What is the big difference with launching with a radial?
Thanks for the input Gary. So is it safe to say that radials will work better with lower horsepower manual transmission cars? So many guys still use radials even though they know it's not as safe with a manual transmission, I'm just wondering why?
As Rob stated, skinnies must be used with bias ply tires. Many guys rather swap out the rears for a DR instead of an entire dragpack. In addition, it is more likely that a DR will be used more frequently on the street so a tire change is not necessary. As for lower HP cars, they break just as easily as high HP cars. Stay away from wheelhop and clutch dumps and DRs will work well. This is easier said than done.
Thanks for all the info guys. I ordered a full set of Hoosiers bias plys for the front and rear. I plan on raising the suspension to stock height and seeing how they fit. I'll be taking it to the track in the next month once I get new belts and a helmet. I'll post some pics soon.
Cheers!
-Keith
Cheers!
-Keith
I put 28x10 Hoosiers on today and did a couple test burnouts and a short launch. After take the slicks off the back there was a decent amount of rubber on the inner fender so they are rubbing. My car was lowered on stock bolts and I recently had it raised a half inch all around to help but they still seem to rub. Here are some pictures. I'll post more after I modify the wheel wells.
About a half inch of clearance inside the wheel well.
